Loosining Distributor for timing?
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey, Yesterday I was trying to do my ignition timing at school (They have a nice Snap On timing light). Anyways, I had to get the distributor loose in order to do it, so I was under the hood, literally using ratchets, extentions, open ends, combinations, small combinations, and it got to the point where I was just dropping everything on to the tranny. What am I supposed to use to get that thing loose? Thanks KP.
Car: check
Engine: check
Transmission: check
Re: Loosining Distributor for timing?
It can be a pain to loosen. On some vehicles I've found that the TV cable runs right across the top of the bolt. Which tends to push the wrench off the bolt.
The bolt head is 15mm, which is difficult to find in a distributor wrench. Others here have used a 15mm socket with a swivel on the extension, or a crows foot.
RBob.
RBob.
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I used a flexhead ratchet wrench and a couple f bloody knuckles. After I adjusted my timing I jest left the distributor snug so that I can turn it by hand whenever I need to but tight enough so that the timing isn't jumping around.
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
Axle/Gears: eaton posi
if u don't have a distributor wrench use a uni-versal joint and an extention and that should do it. thats how i did mine
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
I removed a lot of stuff from the passenger side enine bay, so I just shove my hand in there to hand-tighten, then a rachet to tighten all the way. My old way was interesting: rachet+6" extension+u-joint+6" extension+u-joint+15mm short socket.
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I ditched my a/c a while back and it's slightly easier. Don't have to cram my arm in at a wierd angle atleast.
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
I have a ratched that I bent the handle on one day, while trying to get a siezed bolt loose. It just so happens it's perfect for removing the dizzy bolt.
Engine: 2004 LQ4
Hey Rgauder, sounds good, where abouts are you located?
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I built a 15 mm distributor wrench. Got a distributor wrench from autozone and cut the head off and added a 15 mm wrench on the end then welded it. It has made the whole distributor thing very easy
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I just ground the bolt so that it would fit in my distributor wrench, as I had a standard the next size down....I guess you need it out first though.
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I used a 15 mm open/box end wrench. I had to alternate the wrench from the box end to the open end every 1/8th of a turn. Do that about 20 times and it should be loose enough
Car: 86 Firebird SE
Engine: 2.8L
I had the same issues i got around it by putting 2- 6 inch extensions together with a universal joint and a 15mm socket on the end. You just have to push the kickdown cable out of the way and wiggle the socket down onto the bolt head. With the long extensions, you can turn the bolt from way up top instead of being elbow deep in the motor and loosing skin on the crap sticking out of the firewall. If you have issues getting the socket to slip onto the bolt, just turn the extension the opposite way that your ratchet is switched to, this will turn the socket backwards until it lines up and slips over the bolt, then just loosen as normal. Same principal is used for tightening it back up.
Car: 86 Firebird SE
Engine: 2.8L
trouble is you have a better chance of finding hen's teeth than finding a 15mm dist wrench, trust me i looked. I already had these tools on hand and they work well so why spend extra $$ when you dont have to
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I don't understand why you feel that you need to have the quick ability to change your timing on a regular enough basis to not tighten it down all the way...
Car: 86 Firebird SE
Engine: 2.8L
he might be dialing in the best setting. I know i end up messing with the dist alot when trying to find the best setting when i advance it beyond what they call for stock. I currently have mine set to 12 deg BTDC with no signs of detonation. And its a great way to improve power/drivability. Very common thing with the 5.0 mustang guys, they are 10 deg stock and they take them to 13, 14, even 15 degrees and pick up about 12 horse or so. Works very well for 2.8's too
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
A MAC for $10 or a Snap-On for $20 right now. I'm lazy so I'd rather spend some cash to do it quickly.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
