Anyone clean IAC housing?
Old Nov 24, 2007 | 09:37 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I always wanted to the the IAC housing but I did'nt know if I could find a replacement gasket anywhere or not. There might be alot of carbon built up there that needs to be cleaned out. Anyone ever try cleaning it along with the IAC? Any results after it was cleaned?
Ken
Old Nov 24, 2007 | 10:18 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Anyone clean IAC housing?
I used PB Blaster and it helped the IAC seal better so the idle got better.
Old Nov 24, 2007 | 10:38 AM
ken3983's Avatar
Did you use PB Blaster to clean the IAC valve or did you use it to clean the IAC housing? The housing in which its got around 6 torx or so holding it down to the throttlebody is the one I'm thiking about taking apart and looking inside.
Ken
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
Formula_88AE
Sep 3, 2015 01:47 PM
greenyone
Sep 2, 2015 03:39 PM
