Correct netres for my '165?
Old Dec 2, 2007 | 02:03 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I've posted this in the diy-prom board as well, but here it is again. I've been running a '165 in my '85 v6 camaro for a while now and need some advice on the netres I should be using. I'm getting a code 41 (wrong memcal) and have been swapping in various netres trying to find one that'll run correctly, without much luck. Currently I have netres from an '88 cutlass ('730) ecm and it's running... to say the least. I haven't tried parts from a '90-'92 v6 fbody yet. The main problem with this swap is that the '165 wasn't used w/ any v6's so finding the right netres is difficult. I'm almoast certain an aussie v6 '808 memcal would work, advice?
Old Dec 2, 2007 | 02:13 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Correct netres for my '165?
What is a "netres"? I did a Google and dictionary.com search and came up with nothing.
Old Dec 2, 2007 | 06:08 PM
bl85c's Avatar
Car: '85 maro
The 2 smaller chips on the memcal that hold the limp home info, cylinder select and other stuff. I believe only one is actually a netres (network of resistors) but everyone seems to reffer to both as netres.
Old Dec 2, 2007 | 07:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Are you changing both of the cylinder select parameters in the calibration? No reason you can't use a MEMCAL from a 6 cylinder '7730 app. That will at least fire the injectors at the proper rate. And if you don't want the knock filter just remove it.
RBob.
Old Dec 2, 2007 | 07:50 PM
bl85c's Avatar
Car: '85 maro
I've only changed the cyl # constant, I wasn't aware there was another in $32B. Def. keeping the knock filter, not sure why gm didn't equip the 6's with a knock sensor in the first place. If I'm not mistaken the ecm needs to see a certain resistance from the cyl select pin on one of the netres, is it even the same between those ecms?
Old Dec 4, 2007 | 07:12 PM
bl85c's Avatar
Car: '85 maro
Got it figured out. Had to change the code 41 fueling parameter to v6. Thanks to RBob for clarifying what I was missing.
InfernalVortex
Apr 20, 2021 11:31 AM
3rd gen money
Oct 11, 2019 09:57 PM
jaridjohn
Oct 5, 2015 07:01 AM
sjorgens
Oct 1, 2015 07:54 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
