1987 Pontiac Firebird Problems HELP!!
Old Dec 2, 2007 | 05:10 PM
monkeyboy13's Avatar
Hello,
I have a 2.8L Fuel Injected Pontiac Firebird. It has an issue that really is killer, the problem is as follows; She starts up great, but until she is completly warmed up it runs sooooo rough, the engine pops and everything can anyone help me because i am at a stand still and i cant wait everymorning for this thing to warm up for 15 mins before i can leave HELP ASAP
thank you all its very much appreciated!
Old Dec 2, 2007 | 06:07 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
Re: 1987 Pontiac Firebird Problems HELP!!
get a good tune up
Old Dec 2, 2007 | 06:10 PM
ive gotten a tune up before all fluids radiator etc, ive been told its a head gasket can anyone help me?
Old Dec 2, 2007 | 06:32 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
What color is the exhaust?
Old Dec 2, 2007 | 09:09 PM
it looks to be regular color just a lot of it coming out
Old Dec 2, 2007 | 09:14 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
do a compression check and c if the head gasket is blown
Old Dec 2, 2007 | 09:15 PM
yes, im losing compression, should i just go ahead with the head gasket ?
Old Dec 3, 2007 | 08:04 AM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Sounds like you have found the problem just and make sure you dont have a cracked head when you get it off
Old Dec 3, 2007 | 09:14 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Is coolant getting into the oil?
Old Dec 3, 2007 | 09:38 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If its a head gasket, it should still run like crap when warm too.
Are any of the plugs rusted, or not matching what the rest of the plugs look like?
Old Dec 3, 2007 | 06:49 PM
we have six brand new plugs, could it be a cracked cylinder??!
Old Dec 3, 2007 | 07:33 PM
bl85c's Avatar
Car: '85 maro
Doubtfull. What psi did you get on each cylinder?
Old Dec 3, 2007 | 07:35 PM
im not exactly sure, im going to check it again tommorow what psi should i look for in each cylinder?
Old Dec 3, 2007 | 07:42 PM
cre81r's Avatar
Car: 1992 Camaro RS
Engine: V6 MFI 3.1
Transmission: 700R
Axle/Gears: Stock 3.23
In between 100~150
Old Dec 3, 2007 | 07:46 PM
ok thank you i am gonna get this fixed asap, i have another question does anyone know a site where i can get those screws that right behind the tires in the wheel well b/c my car is missing some.?
Old Dec 3, 2007 | 09:23 PM
Dale's Avatar
Engine: 350 S-TPI
If its just screws, you can use about any. The plastic clips can be found in the help section, or go to a hardware store in the hardware section.
jhawkeye
May 25, 2022 06:33 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
