Distributor problems
Old Dec 4, 2007 | 05:43 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Hello i have a 1992 pontiac firebird V6 3.1l i had a distributor problem and had i new one put in and now the car is not that same i use to be able to take off like nothing but now in the car has to go all the way to 4100rpm before it goes to the next gear and theres alot of power lost it takes so long to get up to speed now,
is it the new distributor or do need new spark plugs or do i need to check the timing because the trans is fine just overhauled it?
Old Dec 4, 2007 | 07:17 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
Re: Distributor problems
yeah, check the timing by all means. Factory setting is 10 degrees. Make sure to unhook the est plug by the blower motor before setting the timing. After it is set plug the est back in and you should be good to go.
Old Dec 4, 2007 | 09:45 PM
Car: 1992 firebird
Engine: V6
ok i will try that
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
