REALLY bad mpg
Old Dec 6, 2007 | 10:35 PM
poppn's Avatar
Car: '85 Firebird, '74 Nova
Engine: 2.8, 5.7
Transmission: T5, TH350
Axle/Gears: 3.42 open, 3.08 open
REALLY bad mpg
Recently there has been a dramatic drop in my mpgs. It's a '85 firebird 2.8 5 speed with 135,000 on the clock. All stock except for custom intake and all new catback exhaust. I'm averaging about 14mpg right now, which SUCKS, compared to what I was getting a month ago (about 19mpg which still SUCKS).
My cat has gone to hell a little over a month ago, it rattles like crazy. I plan on replacing it with a straight pipe tomorrow. The car has had a recent tune-up (cap, rotor, plugs, wires ect within 15,000 miles). I also plan on changing the oil tomorrow as it is beginning to go black after 1,500 miles.
MY question is, why is my mpg so bad??? Can a bad cat cause a 5+ drop in mileage? Is my O2 sensor shot? The car runs great, really lacks power below 2000rpm though, just really really bad mileage.
Old Dec 6, 2007 | 10:47 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: REALLY bad mpg
Have you done a tune up on it TOM P tuen up gudie is great. I bad Cat rattles and also could be cloged could be your problem. I would replaced your cat with a Cat and not s straight pipe.
MPFI ?? could be leaking injectors. Got a fuel pressure tester and see if it holds pressure after shutting it down. Check your plugs seed if there fouled with carbon or oil or white from a blown head gasket.
I only got 19 miles on my 89 2.8 mix of city and country driving. So that could be all that you might get.
Old Dec 8, 2007 | 08:37 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: REALLY bad mpg
my son has an 89 rs 2.8 gets 29-32 mpg all the time runs 93 octane.a bad cat will kill gas milage,so will a bad oxygen sensor,both could really kill it.hope you get it fixed.later jimmy
Old Dec 18, 2007 | 10:44 PM
vintageisbetter's Avatar
Car: 1992 Firebird, 1953 CJ3B
Engine: 3.1
Transmission: 5speed
Re: REALLY bad mpg
use royal purple full synth oil... (after you fix the cat or whatever is turning your oil black so fast) it may cost more but it pays for it self with the mpg help it gives. i get about 5 more miles with it and i know it does wonders on engine life.
Old Feb 7, 2008 | 06:15 PM
ckyfreak2010's Avatar
Re: REALLY bad mpg
go to ur nearest lube center Jiffy lube etc...get a fuel induction cleansing... i have a v6 92 Camaro RS...before i got it i got an atonishing 100 miles to the tank... i got the fuel induction and it seemed to get me a good 3-4 mpg..since your car has many miles there is a lot of carbon build up in the throttle body and the injectors and the fuel induction cleans it out..i went to the Lube Center where i live and it cost $110...also get new spark plugs, wires, and distributor cap and rotor...after getting all of that i seem to get 140-150 miles to the tank
Old Feb 7, 2008 | 11:03 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: REALLY bad mpg
Sounds like a bad injector. Is it rough at low rpm/idle? Smelly exhaust?
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
my86bird
Oct 23, 2015 12:20 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
gta892000
Sep 16, 2015 12:40 AM
