Cleaning up under the hood Shots
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I'm embarrassed to pop the hood on my Firebird because its such a mess. I couldn't find a thread like this, so I decided to make one for V6's.
4th Gen LS1's have the !wire, !ground, !traction control, !everything; anything anyone has done for the 3rd gens? esp V6?
Post your under hood shots and tell what you've done to clean up under there.
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: Cleaning up under the hood Shots
well, they have an auto detailing section just for this kind of thing. but since you asked, use elbow grease on pretty much anything not aluminum or easily removable.for aluminum there is this stuff that you can get at napa for aluminum parts like intake manifolds, brackets, and timing chain covers/water pumps. its supposed to clean it up really well. maybe you could repaint your pulleys and headers if your engine bay starts looking really good. you dont have to focus on the engine either, its just the subject of your pictures. details are important. you can clean up the wiring thats exposed by simply wiping dust off them, clean up the body around the engine, or if you want to draw attention away from nasty stuff, put a little troll doll on top of the engine. people will be so distracted they wont look at all the grime.
Car: 1986 IROC
Engine: 1996 LT1 EFI ODBII
Car: 1992 Firebird
Engine: 3.1L V6
I was kind of talking about rerouting wires or relocating some bulky parts. One idea that comes to mind is the 4th gen washer fluid tank. Ideas, more so pictures of things to clean up under your hood like that.
chevyracingrox, this is v6 specific, so I posted it here.
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
If you start by removing certain systems, you can begin removing many wires. For example, the AC harness is huge and crosses over under the engine on the front. Trace those back to the source and remove them. A lot of wires seem to simply cross from one side of the engine to the other... rerouting those by lengthening and running through custom runways would make things look much nicer. One thing that will make all the difference is painting your brackets. Remove them all, degrease them real good, then paint. Makes a world of difference.
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I'll get shots of my engine bay. I took out the smog cannister and the EGR with alot of the un-needed vacuum lines. It cleaned up the engine bay alot. And the UIM is painted black.
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
Yes,I seen that ,sorry guys, I read the title wrong,I appoligize guys
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
I repainted my valve covers realy glossy gray. new battery and alternator helped. I also passed a small buffer and a fine sand paper to the throttle body and intake manifold. I also painted the black cover for the blower fan and changed the old rusted bolts for nice shiny metal colored ones! and top it of I do about 2 engine shampoos per summer. so my engine bay is spotless.
But I'm still a little ashaimed to pop the hood at car meets because the motor is very small, but I still open it and laugh at it with the other guys and at the same time I die a little inside!!! lol!
I'd post pics but my car is stored for the brutal canadian winter we have here and it's a half hour drive to my car.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I hosed my down with degreaser, and power washed it at the local coin wash. Turned out alright, it keeps my hands a lot cleaner. As for wires and stuff, I have some nice Canadian Tire 'Help' Vacuum line T's, which are about the size of a B-52 Bomber...
Car: 1992 Firebird
Engine: 3.1L V6
Haha, but in that case, its ok
Things like painted valve covers, alright, that can count, but where are the pictures?
I would like to see pictures of people who have done modifications under their hood to clean up / clear some space. FOR EXAMPLE: Replace stock washer bottle with 4th gen style. I wanted some unique ideas to steal to clean up my engine bay (NOT CLEAN IT
) Senior Member
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i know this is v6 specific but im gonna subscribe to this one because mines pretty messy under there too
I do work in a machine shop. though, and if there is interest I can get parts annodized (and/or polish them). I have an extra 3.1 and 2.8 UIM here as a core, then just send me yours.
...and thanx
-john
Car: 1983 G20 Chevy
Transmission: 4L60
http://i89.photobucket.com/albums/k2...7aad3c3dd2.jpg
I may have the messiest 2.8 ever.
I'm fixing that though.
Car: 89 V6 Camaro
Engine: 2.8
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
lol thats kinda old. my maf wiring got destroyed by the past owner.
oil cap fell off, bought a new one today :]
and i'm getting a new engine harness.
I just need a body harness so i can wire tail/ brake lights.
Last edited by Boostin'xr4; Feb 10, 2008 at 09:14 PM. Reason: Automerged Doublepost
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
how did you bypass your MAF i want to do cold air intake but the darn MAF is stopping me?
^^^ What is that under the alternator?
Keep your MAF.
Last edited by firstfirebird; Feb 11, 2008 at 06:02 AM. Reason: Automerged Doublepost
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
oddly enough my afr (based on aem wideband) is 13.9 wot, 14.4 idle and 13.7-14.3 cruising.
so oddly enough it runs way better...
All thats done to it is that filter, and ac/smog pump delete ( short serpentine belt)
it has 370k miles, and doesnt burn a drop of oil :]
Street Lethal
Apr 30, 2019 12:14 PM
