Isn't there any way us V6 guys can have an aluminim block and heads?
Old Feb 1, 2008 | 01:54 PM
  #51
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
Re: Isn't there any way us V6 guys can have an aluminim block and heads?
Originally Posted by grimmcs
^^ That intake is for the FWD 3x00. In order to use those youll need to do the 3x00 top end swap. The only aftermarket intake that works with our heads, that I know of, is the Trueleo intake. But I thought I heard that after testing that it was a bad design and to not waste the $600(?) for it.
Great info, any other tidbits on this?
Old Feb 1, 2008 | 02:13 PM
  #52
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
The Truleo? I think that it does outflow the stock intake a little but not so much that it is worth the $600. It is made of steel too which is another downside.
Old Feb 1, 2008 | 07:33 PM
  #53
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
You could easily get your 180hp goal with a 3x00 top end swap. You won't find any aluminum block cheap, but as far as iron blocks go (rwd that is) the 3.4 is a good choice. It's already set up for dis ignition if you choose to go the 3x00 route, the 3500 heads/induction are compatible (that's what firstfirebird is building) and completely compatible with your stock components. Just by swapping in the 3.4 block (stock heads and all) should get you about 160hp. You could have the stock heads ported, but why waste your money? Just sand out the casting marks and do a little polishing with a ~450 grit foam polishing wheel (dremel makes good ones) and you'll help out flow alot. $10 doing it yourself instead of $100. Stock cranks are well balanced from the factory, they're rated for 7500rpm continuous use. Just make sure to reinstall the rods/pistons in the same order.
Old Feb 1, 2008 | 07:48 PM
  #54
firstfirebird's Avatar
Hah, tell me about it. I can sell a complete 3400 top end and 3100 pistons for the cost of the Truleo, *and* see a bigger improvement
Old Feb 2, 2008 | 11:57 AM
  #55
Engine: 3.1 V6 MFI
This might seem like a dumb question b/c prices for this kind of stuff vary so much state to state, but what could I expect to pay for a 3.4 block and heads from the junkyard? Just a vague range. I would call the junkyards around here, but they don't have any 4th or third gen stuff. It's too popular. I've been to both of them looking for 4th gen seats, got the same story both places.
Q.2 - are the 3.4 block and heads all I need or should I get the computer too? My friend from the forum and I are doing this, so I want to make sure I get everything before this spring so I don't look like a noob before we start the build. He's driving to Lancaster, Ohio from Canton, Ohio.
Old Feb 2, 2008 | 12:21 PM
  #56
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
You reuse the 2.8 computer and sensors.
Old Feb 2, 2008 | 01:18 PM
  #57
Don't use the 3.4 ECM, it's OBD1.5 and the code hasn't been completely cracked.
You should have a '7730 ECM and can be used for DIS.
How soon are you looking? I'm doing a project soon where I'm replacing a low mile Jasper crate 3.4 for a 3500 and the owner will be looking to sell it, but it won't be happening for a couple of months.
He's got a 3.1
Last edited by firstfirebird; Feb 2, 2008 at 01:19 PM. Reason: Automerged Doublepost
Old Feb 2, 2008 | 02:12 PM
  #58
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Originally Posted by firstfirebird
He's got a 3.1
Well in that case then reuse that.
  #59
Engine: 3.1 V6 MFI
Thanks for the correction firstfirebird. Boy would I love to have that 3.4. Let me know how much and I'll try and take it off his hands when the time comes. I'm waiting for spring b/c it's really cold in ohio right now and I don't have a garage, any work has to be done covertly in the parking lot of my apartment and on a weekend when the managment isn't around. LOL
Old Feb 2, 2008 | 03:40 PM
  #60
bl85c's Avatar
Car: '85 maro
You don't need to get the heads with the 3.4 (they're the exact same as your current heads) but you could port them in the meantime so your camaro isn't out of commision while you're doing it. Last time I checked my local yard quoted me $100 for a short block . Probably going to be more just about anywhere else.
Old Feb 3, 2008 | 07:57 PM
  #61
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
oh my god.. I never thought i'd see such a debate over heads..
Bottom line, i'm making 315 crank HP all motor. People with similar built iron head engines are struggling to break 200 WHP.
firstfirebird, nice looking LIM.
Old Feb 3, 2008 | 10:47 PM
  #62
bl85c's Avatar
Car: '85 maro
Old Feb 13, 2008 | 07:32 PM
  #63
nutcase-mark's Avatar
I was look at old post. And saw this one, and got to thinking and there is one place the make aluminim heads with over size valve fully ported the hole bet, for 575 dollars, for gm v6 the 3.1 2.8 and so no.
Old Feb 13, 2008 | 07:38 PM
  #64
I'm only 95% one this one but they also make aluminim blocks bare. But they also make aluminim will a stroker kit in it I'm 150% on the I just don't know if they sale the blocks bare.
Old Feb 13, 2008 | 07:47 PM
  #65
I can beat that for the 3x00 top ends. I sell 3500 top ends for $500 with less than 40k miles on them. 3400 top ends are a little more scarse at the moment, but can be done for about the same price. Both flow far more than the iron heads - even with a Truleo intake.
Dave, that's not my LIM.
This is...
It's getting sandblasted before bolt-down like these...
Old Feb 13, 2008 | 08:36 PM
  #66
But a 3500 top end does not fit on a 3100 block
Old Feb 13, 2008 | 08:55 PM
  #67
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
It will bolt up but the combustion chamber size is larger than the 2.8/3.1 bore so the 3.4 is the only motor you can really use them on. Just get a 3400 top end, they still way outflow the ironheads.
  #68
bl85c's Avatar
Car: '85 maro
Firstfirebird, that engine's better looking every time I see it. Can't wait to see it installed.
Old Feb 13, 2008 | 09:42 PM
  #69
Engine: 450HP 355
Transmission: TH350
I know.. because the one in the pic is mine
Old Feb 13, 2008 | 10:19 PM
  #70
3400 LIM w/ heads and 3500 plenum does
Even the small port 3100 top end is an advantage!
Ah, bragging again
Last edited by firstfirebird; Feb 13, 2008 at 10:23 PM. Reason: Automerged Doublepost
Old Apr 8, 2008 | 07:04 PM
  #71
midwest's Avatar
I got a some questions.
I have a 2.8l
I seen it mentioned to stroke the 2.8 by using the 3.1 crank?
How is this done the 2.8 has 2.493" mains and the 3.1 has 2.647" mains?
I am guessing that the 2.8 block would need to have the mains bored out the proper size to fit the larger mains of the 3.1 block. IS that whats done?
This brings up another question since the 3.1 stroke and the 3400 uses the same stroke, and the mains are the same diameter can i use a 3400 crank?
Then can i bored out my 2.8 block from 3.503" bore to the bore of the 3400
which is 3.62"
If all that is possible the only hurdle is to some how get crank sensor for the dis. But that shouldnt be to hard.
See i want to change my 2.8l dizzy into a 3.4 3400 hybrid dis.
Is this possible ?
Old Apr 8, 2008 | 08:29 PM
  #72
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I have a 2.8l
This is true
Nope, the 1985.5+ 2.8 uses the same size journals as the 3.1.
They are the same crank, most are "981" casting.
which is 3.62"
No.
Is this possible ?
You can go as large as 3.2/3.3L hybrid with the 2.8 or 3.1 block. This block can not be safely bored to the 3.4 bore.
Old Apr 8, 2008 | 08:53 PM
  #73
midwest's Avatar
Originally Posted by Six_Shooter
This is true
No.
I have 02 3400 lined up for real cheap. Would it be a decent combo to put the heads and intakes from the 3400 onto the 2.8l converted to a 3.1? Or would it be better to find a 3100 and use those heads and intakes?
I just ran out and checked my production date is 5/85 so would that be considered 85.5 seeing how they start the production in like oct for the nest year.
Also i checked on all data and they list the crank as 2.49" on years 84 as the lowest i checked, and went all the way till 89 in which they list 2.64" so from 84 to 88. If you know for sure i would beleive you over alldata as i have found errors before.
Old Apr 8, 2008 | 09:13 PM
  #74
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
It is better to get the 3400 heads but the 3400 and 3100 heads are the same after '99 IIRC. Get a 3.4 out of a 4th gen and put the heads on that.
Old Apr 8, 2008 | 09:26 PM
  #75
midwest's Avatar
whats the going rate for a good used 3.4, where can i get one and did they put them in anything else like an s10 or something ?
Old Apr 8, 2008 | 09:31 PM
  #76
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
1993/1994/1995 Camaros had them.
Old Apr 8, 2008 | 11:00 PM
  #77
Engine: 450HP 355
Transmission: TH350
i bet you could grab a Camaro 3.4 for around 3-400 bucks...
Old Apr 9, 2008 | 06:44 AM
  #78
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I picked mine up for $50 but that was only the block and some other parts and pieces. I could go to the local pick and pull and get one for $100, but I would have to pull it myself.
Old Apr 9, 2008 | 07:15 AM
  #79
midwest's Avatar
Ill give my hook up a call and see if he can get me a 3.4 along with that complete 3400. Which hes leting me steal it at 50 bucks. SO maby.....
Old Apr 30, 2008 | 05:18 AM
  #80
91rss's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: 10 bolt 3.23
.. quick noob question about the aluminum block does it have dis connections since its able to be used on fwd applications?
Old Apr 30, 2008 | 11:26 PM
  #81
bl85c's Avatar
Car: '85 maro
I believe so. Too bad it's worth more than my car.
Old May 1, 2008 | 01:31 AM
  #82
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
I'm buyin one to increase the value of my car. Either that or I'll need the 4 bolt splayed mains...
Old May 1, 2008 | 02:28 PM
  #83
4 bolt rear 2 mains will be available from Chevette_Boy on 60*v6
Linson
Oct 24, 2025 02:00 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
69GTOby
Apr 18, 2016 02:34 PM
AmorgetRS
Sep 28, 2015 09:33 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
