HELP! Throttle Body sticking open!
Old Feb 2, 2008 | 11:47 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
So I put my snorkel on yesterday. All went well. (It should be noted that I cleaned my IAC at the same time)
Today I started it so that the battery wouldn't die. This is not my daily driver. The idle seemed ungodly high, like 2500 rpms. But I remember reading on here that in cold weather these cars idle high when first starting. So I went to the post office ot pick up some stamps. When I came back it was up to normal operating temp but still indleing at 2500. I took a peek under the hook and the TB plate thingy wasn't even touching the idle screw! It was like an inch away! So I pushed it with my hand back into the idle screw. Idle went down to 600. It was kinda hard to push. Which it really shouldn't be at all. I went back inside the car and blipped the gas lightly. Same thing: TB plate didn't close all the way, idle back at 2500. I went back under the hood and pushed it back against the idle screw. I then went back into the car and blipped it quick down to the floor and let go. The car very unexpectedly redlined before I could shut off the ignition. As you may well imagine, this scares the heck out of me. I don't want to have to fight my engine to a stop. I adjusted my TV detent cable. No effect. I drove it, let it run for 20 more minute. no SES lights. TB Still sticking open.
So what's up?
Old Feb 2, 2008 | 03:40 PM
Engine: 3.1 V6 MFI
Re: HELP! Throttle Body sticking open!
ummm, I figured it out. The prob is that I'm an idiot. A big fat idiot... there was installation hardware included... the guy put it IN the snorkel instead of in the package. That's all I'm going to say... can I get a moderator to delete this and end my shame?
Old Feb 2, 2008 | 03:41 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
almost sounds like u iac is borked.. hope u didn't push on the needle while cleaning..
Street Lethal
Apr 30, 2019 12:14 PM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
