91 camaro, ground spots?
Old Feb 4, 2008 | 12:34 PM
mnmattie's Avatar
I was wondering where all the ground spots are on the motor? I'm replacing my battery cables and would like to know where i can check all the ground spots are since i'm having a grounding problem! (yes zach this is your car if you're reading this!) thanks!
-Mattie
Old Feb 4, 2008 | 02:03 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 91 camaro, ground spots?
The only two that I know are the battery ground (low on the front of the block) and a ground that attaches on the firewall right behind the passenger head.
Old Feb 4, 2008 | 03:20 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
If I remember correctly there are 3. One in front, as mentioned, and one on the back of each head.
Old Feb 4, 2008 | 03:46 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Its strange, I could never find the one on the backside of the drivers head.
Old Feb 4, 2008 | 03:55 PM
grimmcs's Avatar
Car: 91 Camaro
I jut double checked and on my 3.1 there is a ground on both heads. I wonder if this is a 2.8/3.1 difference.
Old Feb 5, 2008 | 06:49 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Not sure on that 1 b/c the 3.4 has 3 grounds also same as the 3.1, but when I pulled my 2.8 it only had 2. The one on the front and on the passenger side head on the rear.
Old Feb 5, 2008 | 07:56 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Then the 2.8s must have only 2 grounds. I cannot see one at all behind the driver side head.
Old Feb 5, 2008 | 09:19 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Axle/Gears: ?
untrue.. there is a 3rd on the drivers side head.. most people likely cut it since it is hard to reach.
i cut mine by mistake when pulling the engine out of my car.. so i wll have to replace it.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Jae992
Aug 27, 2015 09:07 AM
Cripley
Aug 17, 2015 03:35 PM
