which solid cam and lifter Q
Old Feb 24, 2008 | 12:41 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
looking at crane solid 250801 or 251241 ????? just wondering if 660 lifters are the same as small block lifters ???? just cause there easier for me to get hold of.
oh yeah what valve springs do you guys use for big lift?
Old Feb 24, 2008 | 11:51 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: which solid cam and lifter Q
They're not the same lifters, but the sbc lifters do fit. Might need to have custom pushrods made to correct geometry, but I doubt it. The popular choice right now is LS1 'beehive' springs, they're good to .550" lift but the limit is the heads. You'll need to have the valve guides machined to get any significant lift out of them. The 250801 is the better choice for a mostly stock engine.
Old Feb 25, 2008 | 12:41 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
hi, thanks. i dont know anything about springs yet, so gm v8 springs fit then. being off the shelf OE i guess there quite cheap eh?? instead of branded??
looking at the max lift figures and the lift you want, how far would you 'push' the springs to there limit??????
Old Feb 25, 2008 | 08:39 PM
bl85c's Avatar
Car: '85 maro
You can get used LS1 springs super cheap but I'd never put them on my motor, I always buy new springs. Comp makes beehive springs and retainers or you can use oem parts. Like I said before the limit isn't the springs it's the heads- too much lift and you'll contact the valve guide. The limit on the stock heads is .450"(?) or so. As far as the limit of the beehive springs themselves the listed limit is usually the max you can safely push it without getting coil bind.
Old Feb 26, 2008 | 01:17 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
does anybody like cranes springs that match the cam? (urr 99838) thought itd be best to stick with what they recomend unless there either massivly expensive or just dont work to well....
Old Mar 2, 2008 | 07:47 AM
firstfirebird's Avatar
Not true. The yellow LS6 spring I used coil bound at .5613" lift on 3x00 head using LS1 spring seats/shims. .525" is the safest max lift, people have gone as much as .560" with thinner shims, but I wouldn't trust it - you ever seen a spring in action?
http://www.youtube.com/watch?v=i_NpzU4pGjc
Old Mar 2, 2008 | 09:53 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Quality footage!!!! so is a ls1 spring a ls1 spring or are there different types i should be aware of???
Old Mar 2, 2008 | 10:06 AM
There are a few different ones. They have different colors to denote what ones they are. I used the yellow LS6 springs because they have the most travel and stiffness.
You can get them for about $65-80 new for a set of 16, but I think you can get them directly from GM one at a time.
Ben at 60*V6 did a test on the various LSx springs for seat pressure and max lift, but the site is down right now.
Old Mar 2, 2008 | 10:15 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Its back up now.
Old Mar 2, 2008 | 02:15 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
cant seem to find it ? link? thanks. i like the simplistic and reliable look of the beehive compared to cranes recomended dual setup. what do i need to make small block springs fit our heads? diff retainers & locks?
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
