lovely 2.8l
Old Feb 25, 2008 | 10:30 PM
sloviks88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
lovely 2.8l
well this is the summer i completly redo my car.. my exterior is done and finishing the interior..... now for my lil 2.8l.. i pickd up another one to work on while i show off my newly done maro.. im lookin at getting the stroker kit from a.r.i but im not lookin for the horse power i want toqure. i was thinking besides the stroker kit and the 4.10 gears that will be goin in the back what else could i do some more toqure.. if a cam helps what kind of cam should i be looking for?
Old Feb 26, 2008 | 02:07 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: lovely 2.8l
hi, if i was going for torquey i wouldnt have a 4.10 i personally think youd just waste the torque band. 4.10's abit extreme. a cam would be good everyones each to there own, id look at crane personally, from what these guys say and the fiero boys you cant go wrong really. good luck.
Old Feb 26, 2008 | 11:48 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: lovely 2.8l
If you want to build a torquey 'lil v6 the stock induction is a good place to start (it's good for something atleast). Grab a 3.4 block and throw some dohc pistons in it and a comp solid profile. Top it off with some pacesetter headers and you should have a stout 240ft/lb at 3500rpm. And forget the 4.10's, 3.73's would be better.
Old Feb 27, 2008 | 12:34 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Re: lovely 2.8l
With the DOHC pistons, what'll that put the compression at?
Old Feb 28, 2008 | 12:09 AM
bl85c's Avatar
Car: '85 maro
Re: lovely 2.8l
About 10/1 with .04" gaskets.
Old Feb 28, 2008 | 10:56 AM
Engine: 3.1
Re: lovely 2.8l
I'm looking to build a torquey iron headed 3.4 aswell. I just don't want it to totally fall flat on it's face HP wise aswell.
Thanks b185c
Old Feb 29, 2008 | 02:49 PM
bl85c's Avatar
Car: '85 maro
Re: lovely 2.8l
Well I hate to say it, but it'll still be a turd in the hp department. Unless you do some serious porting to the intake manifold (extrude honing) it's still going to fall on it's face at about 5500 rpm. Even with gobs of torque it's still going to struggle to get past the 200hp mark. Frustrating, isn't it?
You could start by adapting a larger tb to it and port-matching behind it, but you need to be careful with the runners. Open it up too much and you're going to lose air velocity and all that nice torque.
Old Feb 29, 2008 | 03:48 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: lovely 2.8l
I am building a 3.4 like these guys are describing. I am shooting for 200hp. I got a Comp 260H cam with a 114 lsa, ported heads, DOHC pistons, 1.6 roller tip rockers, LTs, and will be porting the manifolds as much as possible.
Old Mar 5, 2008 | 09:52 AM
john1483's Avatar
Re: lovely 2.8l
hi there I got the same car same year same engine same trany and same paint beautifull car
Old Mar 11, 2008 | 09:54 PM
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
Re: lovely 2.8l
ok well say ur driven down the interstate and someone flies by you n you wanna be a tuff guy and passin him what would be better more tq or hp?? ive been wondering about that question for a long time
Old Mar 12, 2008 | 11:58 PM
bl85c's Avatar
Car: '85 maro
Re: lovely 2.8l
Horsepower. Basically torque gets you moving, hp keeps you accelerating.
Old Mar 13, 2008 | 01:41 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: lovely 2.8l
ive always liked engines with equal amounts of T & HP so once you get started on the torque theres just a constant stream of non stop train like power from low down with no peakyness to it. nice. torque will get you going quicker to catch him hp will get you flying past
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
bplessy
Sep 30, 2015 12:14 PM
