Starter issues
Old Mar 6, 2008 | 06:35 PM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
Starter issues
I have just put the motor back in to my 86 camaro. IT is a 2.8 my qestion is did i leave something off the starter. I put the bat and the two other ways on the big post. and then the one wire onto the small post. Put the starter want do nothing with i turn the ingtion. I dotn have all the wires hucked back up yet just trying to make sure my starter is good befor i put the manafold back on. Easy to get to the wires on the starter. And as always thanks for any help.
Old Mar 6, 2008 | 08:07 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Starter issues
There is no reason to do anything until all of the wires are hooked back up. The starter will be easy enough to pull back out if there is a problem.
You should test your starter BEFORE you put it on if you are worried about it. Either bench test it, or take it to your local auto parts store and have them test it.
Good luck!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
