crank pulley.....
Old Mar 13, 2008 | 03:21 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
crank pulley.....
SO i ordered a crank pulley for my 86 2.8......
and it doesn't look like it will work. Did they change the belt setup with the 2.8's?
Mine has two belts.....and the pulley I got only has one.
Old Mar 13, 2008 | 03:23 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: crank pulley.....
Yes. The earlier models had v-belts, the later had serpentine. You've got a v-belt from what you're describing and that pulley is a serpentine pulley.
Old Mar 13, 2008 | 03:28 PM
Engine: 2.8L - 6.3L
oops.
I guess I need to return this........phooee.
Do they make UD pulley's for mine?
Old Mar 13, 2008 | 03:59 PM
forkvoid's Avatar
No idea on that one. Sorry.
Old Mar 13, 2008 | 05:45 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
try advanced, autozone, carquest ( they sometimes have tough to find parts), napa.
if all else fails and u need it bad, junkyard or dealer.
Old Mar 13, 2008 | 06:34 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Check out this part # at Summit.... JET-90108
It says its for you year, but it looks like its for a serp. set-up.
Although if you look up this number... ASP845200 ...it shows as a 2.8 crank pulley. Than if you go to ASPracing.com you will see that that part number is for the 2.8 Fiero.
Anyone know if it will work for his engine?
Old Mar 13, 2008 | 09:35 PM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
the 85's (and i'm assuming the 86 up to whenever they switched to serpentine) had one flat belt running the alternator and one v-belt running the ps pump...
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
