intake question
Old Mar 12, 2008 | 07:11 PM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
intake question
Hey I am about ready to start up my motor after a rebuild. My question is can I start it up with out the top part of the intake on just the lower and the injecters. Cause i dont know how much room is there for adjusting the timing. Thanks for any help with this.
Old Mar 12, 2008 | 07:32 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: intake question
Adjusting the timing can be done with the motor all together.
Old Mar 12, 2008 | 10:16 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: intake question
I would think that starting an engine without the UIM/TB would be disasterous. There would be no way to regulate RPMs, they would shoot really high, and would probubly seize/blow-up your engine.
But than again Ive never heard of doing this so thats just a guess.
Old Mar 13, 2008 | 01:44 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: intake question
would it shoot high though with no map/maf to read on? or would it use o2 sens and try to rectify? whatever DONT do it timing's easy all together and only takes ten mins.
Old Mar 13, 2008 | 07:45 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: intake question
It would shoot way high and blow your motor. Without a TB to regulate the air the motor is going to take in air as if the TB was at WOT. The timing isn't that difficult to adjust with everything together. Just loosen the hold down bolt just enough so that you can turn it. The dizzy will rotate very easily.
Old Mar 13, 2008 | 06:46 PM
83camaro86's Avatar
Axle/Gears: stock
Re: intake question
Thanks for the info. This is my frist camaro V6 build. And the frist for fuel injction. I have came across another questioon. Does the TB huck up to the heater lines in front of the motor? Thats what it looks like it does just not sure. and again thanks for the help.
Old Mar 13, 2008 | 09:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: intake question
It does but it is a pain to hook up and disconnect the TB. I would just bypass it.
Old Mar 14, 2008 | 04:15 PM
83camaro86's Avatar
Axle/Gears: stock
Re: intake question
Good to know that i can bypass it. Do I need to do anything speacal to it? And also on the back of the UIM. IS that where the brake line hucks up to? I know it needs vac on it to work.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
