3.1 injectors on a 2.8
Old Mar 13, 2008 | 08:22 PM
dunnellon86's Avatar
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
i went to the bone yard and pulled some ijjectors off of a 1990 3.1 v6 and was wondering and hopeing thay would fit/work on my 89 2.8 v6????
thanks
Old Mar 13, 2008 | 09:38 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 3.1 injectors on a 2.8
They will work. They look a little different but they work. I have been running them in my 2.8 for about 9 months now without any problems. You will run a little rich at idle but not too bad. I like them better than the 2.8 injectors I had.
Old Mar 14, 2008 | 11:18 AM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
thanks good to know by the way will the rail work too or do i need to pop the injectors off and put them on my old rail and what do i use to clean the ijectors off? thanks
Old Mar 14, 2008 | 01:31 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Just get some brake parts cleaner. That will take alot of the old stuff off.
Old Mar 14, 2008 | 01:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.1 and 2.8 rail are different because of the cold start injector piping.
Ive used carb cleaner and rubbing alcohol on my injectors.
Old Mar 14, 2008 | 07:50 PM
923.4v6's Avatar
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
what # injectors do the 3.1 & 3.4 have stock?
Old Mar 14, 2008 | 08:15 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
i think its 17lbs for both i could be wrong though
Old Mar 14, 2008 | 09:59 PM
923.4v6's Avatar
Car: 92 Camaro RS
thanks, any recomendations on any bigger injectors. going to 11.5 to 1 compression.
Old Mar 15, 2008 | 02:16 PM
Dale's Avatar
Engine: 350 S-TPI
search
2.8 weak 15lb
3.1 strong 15lb
3.4 17lb
Old Mar 18, 2008 | 01:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I thought that 87-88 was the last year for the CSI?
If not, and you have the seventh injector, then yes, you have to swap the injectors over to the old rail (GP-Sorenson 800-9220 injector o-ring kit, will have four leftovers, $9 @ Advance). Just DON'T lose the o-ring on the CSI tube... you WON'T find another one except in a kit that has gaskets you won't even need.
BTW, go to a store and pick up the intake manifold set, FelPro MS-93020 and replace your upper end gaskets while you are at it. You won't regret having done so. (Might as well since you can only get the plenum gaskets in this kit, which you will need to even get at the fuel rail).
92-Formula
Dec 12, 2015 10:34 PM
Zane Story
Oct 8, 2015 12:40 PM
webeeZ28
Sep 14, 2015 12:00 PM
rjcme
Sep 5, 2015 01:23 PM
