Ok, Who's the comedian?
Old Mar 20, 2008 | 01:00 PM
Drew's Avatar
I came across this on the TurboFord forum and though it was worth posting here. Guy that took the pic found this in a junkyard in California.
Old Mar 20, 2008 | 03:09 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: Ok, Who's the comedian?
Wow...I would imagine that would let the engine "breath" a lot better. Ive seen that design before...but not in a v6 F-Body.
Old Mar 20, 2008 | 04:08 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Interesting. Do you have a link to the thread? I'm interested where the previous car's owner got that from.
Old Mar 20, 2008 | 04:13 PM
Drew's Avatar
I could link to it but it's a closed forum and there isn't any more information there, than there is here. All the guy said is that he saw it in the junkyard and took the pic. Somehow I doubt 6 carbs would suddenly make a 3.1 run much better. Maybe someone just wanted something different... Anyway I figured someone here might find it interesting or funny.
Old Mar 20, 2008 | 04:20 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Actually that set up is alot better than the stock manifolds. They are pretty resrictive stock UIM). It would give the car a little more power I would imagine.
Old Mar 20, 2008 | 07:20 PM
Drew's Avatar
Probably not since it obviously never drove with that intake. Assuming it had been done correctly most people could never get the individual carbs tuned correctly for the engine to reach optimum performance.
Old Mar 20, 2008 | 08:53 PM
grimmcs's Avatar
Car: 91 Camaro
Oh I didnt see that they were carbs Ive seen individual TBs...If you could get that design to work with TBs though it would help out the engine though...along with a lot of other add-ons.
:EDIT: This was the concept I was thinking about...
the Ryan Falconer intake he design that allowed the 2.8/3.0 race motors to make 100hp/liter. His intake had 6 butterflies the same size as the stock TB. His formula was pretty simple...use the GM high compression forged pistons 12.5CR, mechanical cam w/ .540 lift, hi flow intake with individual air delivery per cyclinder, as well as injectors mounted in then top of the intake runners.
Old Mar 21, 2008 | 01:33 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
im thinking of this now TB's would be well easy to set, stock injection/computer will have it runnin smooth with some beefed up bronco injectors. nice. carb builds outa window now ive got gen II heads so need somin this interesting to keep the build different
Old Mar 21, 2008 | 01:52 AM
Drew's Avatar
It really looks to me, like someone took a stock lower intake, (note the temp sender next to the coolant hoses to the missing throttle body), and welded the uprights in place to the carbs. Judging from the wide open EGR, and the support bracket for the intake ducting, the coolant hoses, and the throttle cables, I'd had to assume that someone lost interest or otherwise gave up before it was finished and had it hauled off for parts. Maybe some poor guys exwife got it in the divorce and push/pull/dragged it. It kinda looks like it's sporting silver minivan style valve covers too. So far no one on either forum it's posted on really has a clue as to it's origin. I'm sticking with homebrew.
Old Mar 21, 2008 | 10:56 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
They look just like the carbs on one of my Honda bikes. If memory serves they look very close to my '73 CB500, which should actually have '81 CB650 carbs since the bike other than the frame is '81 CB650.
Old Mar 21, 2008 | 12:22 PM
Drew's Avatar
Someone on the other forum theorized they're from a Kawasaki 750...
Old Mar 21, 2008 | 01:46 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
a variation of the 6 pack
Old Mar 21, 2008 | 01:52 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Look to be mikuni carbeurators.. Good luck starting that car..
Old Mar 22, 2008 | 11:18 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
That's cute.
vindoo
Jun 3, 2006 09:15 PM
buddman91rs
Oct 30, 2001 10:15 AM
buddman91rs
Oct 10, 2001 01:24 AM
