2.8 cold start vavle
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
Has any one just puged off the cold start vavle. Mine is leaking on the fuel rail. Its has a little play in it. I was woundering if this would work. Its from summit. Or does my motor have to have it. Thanks for the info
http://store.summitracing.com/partde...5&autoview=sku
Re: 2.8 cold start vavle
For a hell of a lot less money then $80, you could get a 3.1L fuel rail, injectors, sensors, ecm, harness, etc and just convert to the later engine management.
Axle/Gears: stock
But if i wanted to get this from summit would the motor still run right with out the cold start vavle and tube? would the 2.8 manafold still work with the 3.1 set up or would i need to change that also? Thanks for the help
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
It's only used at startup. You could plug it, but it would crank longer before starting. A '730 conversion would be a lot of work just to get around a leaky cold start injector, but it's a good ecm anyway. To do it you'll need to plug the cold start injector, switch to an electric egr, wire in a knock sensor, ditch the maf, repin the harness (switch connectors too) and wire in a map sensor. It should run fine with the 2.8, but if you want a 3.1 all you need to do is swap cranks and pistons. Or keep the stock ones and have them milled.
Axle/Gears: stock
Well how could i fix the cold start vavle. IT is leaking on the fuel rail. I have replaced the o ring on it but the tub that goes to the fuel rail is still loose when dthe nut is tight. YOu can push and pull up in and out not much but enoght for it to leak I dont know if it is leaking on the back side or not. Tanks for the help
Axle/Gears: stock
Sorry I mean tube.
I think i found the problem. Looking back in some old pics I saw that the o ring was bigger then the one that napa gave me. So to find out the o ring i bounght was to thin for it. I found the o ring and now she is leak tight. Thanks for all the help.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
