3.4L Track Times
Old Apr 11, 2008 | 05:44 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
3.4L Track Times
What times do you think are possible,
3.4L Forged Longblock
Cast Iron Performance Heads - w/3 angle valve job
Phase 2 Cam - lift .420 exhaust .443
Stock intake w/ 19lb Injectors
Msd Ignition
Performance 660 700r4 Trans
10 Bolt Posi w/ 3.23's
Car weights around 3200
Do you think 14's are possible
Old Apr 11, 2008 | 07:40 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 3.4L Track Times
Should get you high 15's. The 3.23's are gonna really kill you.
Old Apr 12, 2008 | 09:36 AM
kelham's Avatar
i have a non posi rear just sitting around out of my original v6 with 2.73s or something like that... do you think that will be more suitable ??? whats the best gearing for the car?
Old Apr 12, 2008 | 09:53 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
2.73s would make you even slower. A good set of 3.73s or 4.10s will help you. Those 3.23s are an improvent over the 2.73s though. I'd exepct for you to run mid 15s at the highest. Thats what I am shooting for with my motor being built.
Old Apr 14, 2008 | 02:40 PM
kelham's Avatar
yeah i wasnt sure, people talk alot about the v6 rear being more desireable, swapping in 373 isnt too bad, when the build is finished the 3.4 stroker should be around 200 to the crank
Old Apr 14, 2008 | 02:53 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Probaby why people want the V6 rears is that we had better gears and they are everywhere in the boneyards.
Old Apr 14, 2008 | 03:23 PM
firstfirebird's Avatar
Forged bottom end? What crank did you use?
Old Apr 14, 2008 | 11:49 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
And why waste it on 200hp? Or do you have something planned that will need a forged bottom end?
Old Apr 15, 2008 | 06:46 AM
kelham's Avatar
figured i might as well just incase i ever really want to spray or add some boost, firebird- i've talked to ari about it alot, they offered a forged crank for an additional $200 in their 3.4L motor. Not sure on part numbers, the engines due to arrive in 2 weeks so if theres p/n ill let you know
Old Apr 15, 2008 | 08:38 PM
I'm wondering what they are considering forged. A 60* forged crank costs about $1200
Old Apr 15, 2008 | 11:54 PM
kelham's Avatar
yeah im aware, i think the company is TRW or something makes forged pistons but their like 600-900 bucks for the set. I know the crank is forged though, i passed on the pistons, went with hypereutectic pistons, the motors running around 10.1 comp ratio, wish it was a little lower im looking at running a low boost procharger on it, customizing some brackets and giving it a go. prob round 5psi with a 600 series. Thats off in the future for now though, i gotta get the motor and trans in in a few weeks and get some suspension mods done and finish my interior. it just comes down to time???
Old Apr 19, 2008 | 01:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
a lil for ya when i was fartin around w/the Poncho 400's back in early/mid 90's:
a nodular iron crank will flex before snappiing, forged crank will just snap.
fwiw, the original owner of my camaro got that thing to scream the 1320 in 15secs, 5sp W/3.42 rear from v8 donor. It does 16.5 now w/140k or so on the odometer & 1-2 sift not all that when stomped.
edit: also, (caint remember if the 87's still had this, but) rig the cold start injector for that extra umph.
Old Apr 19, 2008 | 11:59 PM
bl85c's Avatar
Car: '85 maro
What do you mean by 'rig the cold start injector'?
Old Apr 20, 2008 | 08:34 AM
You have it backwards. Cast will snap before flexing, fogings will bend.
Do you think a cast rod could do this?....
and this is what happens to pre-86 cranks when making power (nodular iron)...
You can't tell me the racing world has been using forgings for years, cast iron is not stronger or more flexable.
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
