nitrous questions
Old Apr 14, 2008 | 06:14 AM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
nitrous questions
Im going to be picking up a universal wet kit in a few days and i have a few questions;
1.How long will it take to install im estamateing around 4-5 hrs
2. Where should i mount the nozzle closer to the TB or alittle further back
3. I know i get the fuel from the test valve but is it a special size or are they a standard size for the most part.
4. Im only going to run a 50 or 75 shot im assumeing thats safe
I have a 2.8 if that matters.
Old Apr 14, 2008 | 09:43 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: nitrous questions
hi, i asume you would get instructions for the best mounting point - all systems vary a little, so pay attention to those particular instructions.
the test valve on the fuel rail ? is just a schrader valve
on the nozzle size id start small and see how the car responds - how old is the motor? how many miles??
Old Apr 14, 2008 | 10:07 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
50 and 75 shot is pretty safe for a stock motor, depends on miles too. Like zs&ts said, start small and work you way up. You don't want to run lean when running NO2. Do a search since there are a few people here who have run NO2 on these motors stock.
Old Apr 14, 2008 | 02:05 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
well im thinking about just keeping it at 75 shot max the motor has about 62000 on it not bad altho im currently driveing with no maf but ya the car runs fine i think it would handel a 50 shot pretty well.
Old Apr 14, 2008 | 07:14 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
Kit Number 07005NOS is intended for 4 & 6 cylinder applications. This kit was designed to be used on late model multi-point fuel injection type engines with 43 psi ± 5 psi fuel pressure.
^^ thats from the instructions does the stock fuelpump output 43psi at the schrader valve??
Old Apr 14, 2008 | 07:24 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
The fuel pressure in these cars should sit at 45 psi if I am not mistaken.
Old Apr 14, 2008 | 08:30 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
ok sweet I cant wait to get it all installed and test it for the first time with the smallest shot an work my way up!!!
Old Apr 14, 2008 | 11:58 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I don't think I need to tell you to put the maf back in first, but I will anyway.
Old Apr 15, 2008 | 12:43 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
driving around without the maff isnt a great idea ^^^^2nd
Old Apr 15, 2008 | 02:13 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
Ya hopefully I get around to ordering one
MustangBeater20
Oct 29, 2022 09:20 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
