running choppy (maybe mis-fire)
Old Apr 23, 2008 | 09:04 PM
marco93L's Avatar
Is there a common problem with the 2.8's to have a shoppy idle or even while running down the road? I cant seem to figure out what is wrong with mine. I have replace the plugs, wires and the cap and rotor with good parts, not the cheap ones. And I still have the same problem. It acts just like there is a mis-fire. I could be wrong, but I am pretty sure that is what it is. it acts like you shut off the car for a split second and it does it all the time, under light acceleration, full throttle, or idleing
Thanks for any help
Marco
Old Apr 23, 2008 | 09:32 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Re: running choppy (maybe mis-fire)
recheck plugs might be "gap bridging" build up between the electrode and metal tab, check spark plug wire resistance, check compression.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
