which fuel regulator?
Car: 89' Firebird
Engine: 3.4L V-6
Transmission: 700-R4
Axle/Gears: Whatever came stock!
Ok, I swapped my 2.8 to a 3.4 about 1,000 miles ago (runs great), 3.4 injectors and what not, but I checked and it seems that my fuel pressure regulator is going bad. The one in there right now is for the 2.8.
So my question is, should I go with a regulator for a 3.4? I heard that either a 2.8 or 3.4 regulator will work, and that they may be the same thing. Which do you think will work better??? Going with a stock part, thanks!
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: which fuel regulator?
For what its worth I am running a adjustable BBK regulator for a TPI on my V6 ..the adjustment screw will need to be shorter in length ..hits the bottom of the upper plenum.So that could be an option for you?.
Car: 89' Firebird
Engine: 3.4L V-6
thanks for the reply guys. I just lookep it up from the dealer, and the 2.8 and the 3.4 use the SAME regulator. Im gonna keep those aftermarket ones in mind though
9192camaro
16
02-03-2019 12:21 AM
ambainb
04-25-2016 09:21 PM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
