TB cooling 'thing' snapped in half....? (Pictures)
Old May 13, 2008 | 05:55 PM
threepointone's Avatar
Car: 1991 Camaro
Engine: LH0 3.1L V6
Transmission: uhh... an automatic one.
Axle/Gears: um... these ones... *points*
I was going to do the TB bypass anyway, but I noticed the coolant 'thing' (not good with parts) snapped in half near the threading which is causing a leak. Can anyone tell me what it is called, and if I can just plug up this hole instead of getting a new part?
This is what I'm talking about...
http://i105.photobucket.com/albums/m...e/IMGP0001.jpg
This is a closer look at the situation...
http://i105.photobucket.com/albums/m...e/IMGP0002.jpg
This is what a tube from it goes to...
http://i105.photobucket.com/albums/m...e/IMGP0003.jpg
THANKS!
Old May 13, 2008 | 05:58 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: TB cooling 'thing' snapped in half....? (Pictures)
I have mine plugged. It goes to your heater. You'll have to cap off the entire loop. The other end is on the water pump; just put a hose cap on it and clamp it down. Without those plugged, you'll have no heater, since coolant won't be getting to your heatercore.
Old May 13, 2008 | 06:30 PM
project89's Avatar
hows that working for you?? cause that also alows water to circulate when the thermostat is closed. i pluged mine on my car since i have no heater or ac in mine anymore,but in doing so i was told not to runa thermostat since there was no way for water to bypass it
Old May 13, 2008 | 07:29 PM
forkvoid's Avatar
It's a temporary solution. I ran with it like that for about two months as my DD before taking it back off for the 3.4 swap. I put it back in just to plug the hole until a 2.8 comes back into the yard so I can get the correct fitting.
Old May 14, 2008 | 06:36 PM
planman's Avatar
Car: 92 RS
Engine: 3.1 V6
Mine did the same thing. I removed the hoses to the throttle body and capped off the hose connections with vacuum caps; removed the metal tubing to the heater valve and capped off the connection at the heater valve with teflon tape and a brass cap; sealed the hole by the thermostat with JB Weld after grinding down the remainding threads with a Dremel.
I live in Central Florida so I really don't need heat. There have been no bad effects at any speed.
Old May 15, 2008 | 09:30 PM
Car: 1991 Camaro
Engine: LH0 3.1L V6
Thanks for the info guys!
I ended up getting a chromed out 1/2in heater hose adaptor from the "muscle car" section at autozone for $10. I chizzled (sp?) out the corroded pathetic original part that cracked, then put in the new one with some high-heat sealant on the threads. Then I just ran a 2ft hose to that black valve thing. TB is now bypassed, which was the main goal!
Thanks again- it's good to have a place to go for this kind of stuff!
Fronzizzle
Mar 18, 2019 08:29 PM
mdtoren
Aug 23, 2015 12:52 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
