PLEASE HELP SOMEONE GOT TO KNOW
Old May 18, 2008 | 02:14 AM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
i have a 90 3.1 auto camaro and i have a couple issues that i think are all intertwined first my car would die at stops usually on a slight hill but it would stumble on flat ground this only happens once in great while. it also revs up to about 4000-5000 rpm right after i start it.on top of that i have trouble code 32 and 45 and i have smog next month so any help would be greatly appreciated thanx
Old May 18, 2008 | 02:32 AM
threepointone's Avatar
Car: 1991 Camaro
Engine: LH0 3.1L V6
Transmission: uhh... an automatic one.
Axle/Gears: um... these ones... *points*
Re: PLEASE HELP SOMEONE GOT TO KNOW
Sound's like you need an all-out TomP tuneup.
Old May 18, 2008 | 05:11 AM
cre81r's Avatar
Car: 1992 Camaro RS
Engine: V6 MFI 3.1
Transmission: 700R
Axle/Gears: Stock 3.23
EGR and your car is running rich.It calls for a tune up.
Old May 18, 2008 | 05:16 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
code 32 has to do with your EGR and 45 is from your o2 sensor saying you are running rich.
For the dieing and high idle, I would look at your vac lines. You might have a leak somewhere.
Old May 18, 2008 | 08:53 AM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
check for a leaking injector or a split fuel pressure regulator diaphragm...
Old May 18, 2008 | 09:50 PM
SageMoonblade's Avatar
You may have blown out a spray tip of an injector, happened once to me, causes the fuel to not fully atomize and can cause a seemingly rich condition. Do you notice any dark smoke from the exhaust?
Old May 19, 2008 | 12:13 AM
Car: CAMARO RS
it smokes a little when i start it it runs good most of the time the vac lines spark plugs tps egr map air temp sensor ignition control mod ecm cat converter fuel pressure reg pcv iac cap and rotor and o2 were all replaced 2 years ago. the spark plug wires air filter and fuel filter were all replaced a less than a couple months ago. the ses light seems to come on more when i put ampm gas in it. could that affect it or is it just a coincidence the reason all these part were replaced is because when i got the car it had major issues and would not pass smog.
Old May 19, 2008 | 01:02 PM
Have you checked your timing?
Old May 19, 2008 | 02:02 PM
Tookie's Avatar
Bad or leaking EGR will cause all of these problems.
Make a little block-off plate to put in between the gasket and
the intake manifold, where the EGR tube meets the intake - that'll
let you see if it's the problem, before dropping big bucks on the EGR
Old May 19, 2008 | 04:42 PM
ramshead's Avatar
i had the same problem with my 89 2.8 had it for 11 yrs what it needs is agood tune up every fall .cap,rotor new plugs @ wires. also check your egr vacuum assembly. i once had a mechanic break one of the plastic vacuum lines and neversaid athing.made the engine very sluggish going uphill.which eventualy broke the piston in the egr valve.made it stall every time i stopped.had to secure it to the manifold with a coat hanger.those are just acouple minor fixes but they can drive you nuts.the engine still ran like a top until i got rid of it in 06
Old May 21, 2008 | 03:08 AM
Car: CAMARO RS
today i did my spark plugs and it still revs up and runs rough at stops i notic when it does this that my battery gauge also goes down a little
Old Jun 3, 2008 | 03:09 AM
Car: CAMARO RS
i replaced the egr valve and it stopped revving up and staling out thanks guys
