Just wanted to say.. The 2.8 passed the 2008 Ontario E-test.. Results are..
Old May 28, 2008 | 06:59 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hydrocarbon - Limit : 60 Result : 17 PASS
Carbon Monoxide - Limit : .33 Result : 0.0 PASS
NO ppm - Limit 675 Result : 450 PASS
RPM : 2815
IDLE 709 RPM
Hydrocarbon - Limit : 200 Result : 59
Carbon Monoxide - Limit : 1.00 Result : 0.08
So this shows, 211 000KM, leaky valve seals, a cracked manifold and a 2.8 running extremely rich can still be a clean driving vehicle.. Although, the cat has less than 10k, and the Flowmaster 80 series muffler has less than 100 km's on it..
Old May 28, 2008 | 10:06 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Just wanted to say.. The 2.8 passed the 2008 Ontario E-test.. Results are..
Your limits at idle are way higher than we have here in CA.
Congrats on passing.
BTW, you're not actually running rich at all. Carbon monoxide is your rich indicator and with numbers like you have, I would actually say you're running a little on the lean side, not too bad, but just a smidge.
Old May 29, 2008 | 05:49 AM
Kevman's Avatar
Engine: 2004 LQ4
It looked to be running rich, after I redid the exhaust there was black runny marks everywhere.. Weird cars...
Old May 29, 2008 | 10:11 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
The black is not uncommon, it's made up mostly of impurities in the fuel, not actually fuel. Some areas are worse than others depending on the fuel being used there.
We see it a lot in California with the fuel blends we use here. It has a lot to do with the detergents that "clean" the gunk off valves and other engine parts. The solvents get it off the valves, suspend it in the air charge and it gets shot out the exhaust, cools and settles in the exhaust pipe. Most of the time, it's in the low spots.
If you ever get the chance to crawl under a newer car, look for the drain holes that are specifically placed in the low spots to allow that stuff and water to get out before it solidifies.
Cleotiz
Jan 6, 2018 08:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
E Rod
Aug 28, 2015 05:17 AM
wruiz
Aug 11, 2015 02:59 PM
djmarch
Aug 9, 2015 05:27 PM
