3.4 swap A/C Hookup
Old Jun 8, 2008 | 07:31 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
3.4 swap A/C Hookup
For those that have done the 3.4 swap did you hookup the a/c too. I know the lines from teh 3.4 a/c setup are too long and hitup against the frame when you try installing them. So if you did hook up the a/c what was your course of action? I don't think I can foot it through another summer of 100+ degree temps.
Thanks in advance!
Derick
Old Jun 8, 2008 | 08:11 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: 3.4 swap A/C Hookup
The 2.8 lines should fit fine... all you did was swap the shortblock, which is almost identical to the 2.8/3.1.
Old Jun 8, 2008 | 09:21 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Which version of the 3.4 swap are you/did you do?
As mentioned, if you just did the longblock swap, ac should not be an issue.
If you did the full wiring/SFI swap. You will be the first in an fbody. I know the threaded connections are different sizes. I'm surprised the pump would clear the cross member. I know it was damn close on my s10, and looked tighter on a camaro.
Old Jun 8, 2008 | 09:29 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
I didn't do the entire wiring and all but I did use the 3.4 setup with the a/c compressor on the bottom passenger side of the engine. And yes you are right the main line feeding off the back of the compressor hits the cross member so I think I need to make another line. I have a place here that makes hoses and I'm gonna see if they can do some welding for me to make a 90 degree angle coming off that 1 line and then I think I can set it up fine from there. I'll take some pictures tomorrow so you can better see what I'm talking about. I have the lines from the 2.8 and 3.4 setup so I should be able to get something done out of them.
Frozer!!!
Jan 19, 2024 04:55 PM
BikeFarm
Aug 11, 2015 11:35 PM
92projectcamaro
Aug 6, 2015 01:20 PM
