Vaccuum line question
Old Jun 15, 2008 | 10:10 AM
Camatruder's Avatar
Car: 88 Camaro V6
Hello,
I'm currently restaurating a 1988 Camaro V6 + T5-transmission.
Between the engine and the firewall, there's a 3-way-piece on the vaccuum line. One end is closed with a screw. I can't believe this is stock. What is supposed to be there ?
Thanks.
Old Jun 15, 2008 | 12:33 PM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
Re: Vaccuum line question
If it's the middle section of the 3-way vacuum valve, then it goes to the charcoal box in the front driver's side of the car under the hood. (It is for emission purposes.) That's why it is plugged.
Old Jun 15, 2008 | 02:18 PM
Camatruder's Avatar
Car: 88 Camaro V6
It is the middle section of the 3-way-valve, but at the carcoal box there are hoses on all possible places.
Old Jun 15, 2008 | 04:38 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
That's actually not the charcoal canister. One end goes to the intake, the opposite goes to the charcoal, and the perpendicular line goes inside the wiring harness. It's to the HVAC control, I believe. I've attached pictures.
Attached Thumbnails Vaccuum line question-img_1812.jpg   Vaccuum line question-img_1813.jpg
Old Jun 15, 2008 | 06:10 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
perfect timing! i was wondering what that one does!!! alright how about the black cylinder bolted on with the alternator?
Old Jun 15, 2008 | 06:56 PM
forkvoid's Avatar
Picture? Bolted between the alternator and water pump? Fancy valve breather, I believe. If so, in theory, you could gut a large portion of the vacuum line system and replace it with a simple open-air valve breather directly in the valve cover.
Old Jun 16, 2008 | 08:36 PM
i'll post a picture as soon as someone tells me how the **** you post pictures!!! lol, seriously though, i have no idea how to post pictures. i'll take the picture though.
Old Jun 16, 2008 | 08:54 PM
forkvoid's Avatar
Here is how: https://www.thirdgen.org/forums/prob...mages-tgo.html
Old Jun 17, 2008 | 12:30 AM
thanks, i think i figured out how to attach photos now.
Old Jun 17, 2008 | 07:42 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I have an open breather on that side also though its a filter. Are you running a PCV valve in that?
Old Jun 17, 2008 | 08:48 AM
forkvoid's Avatar
I'm fairly certain that's the valve breather. I've got one on mine. Some years don't have it, some do. I'd love to get rid of the entire bit, but as you can tell, the bar the breather sits on holds the alternator in place. You could rip that whole mess out, put in a standard open breather, and with some analyzing of the vacuum lines, cut it down tremendously.
Old Jun 17, 2008 | 01:05 PM
i'm not "running" anything YET! but i was planning on doing just that.
sounds like something to look into. i know its held on by 2 pins on that plate. you could probably just take a torch or grinder and take it off, but i'm not messing with that now. i'm just going to focus on getting it running and then i'll mess with making more power and stuff like that.
so any comments on the engine paint?
Old Jun 17, 2008 | 02:06 PM
forkvoid's Avatar
Painted it with it all together, judging by the orange colored bolts. You've got overspray on the valve cover. It's still much better than the GM Corporate color(black), just seems like a sloppy job. I'm guilty of it too, though: masking a built short block is a major undertaking, so I put the heads on and masked them, with the result being orange colored head bolts.
Old Jun 17, 2008 | 10:04 PM
yea, i was in kind of a hurry to get the engine in so i just painted it as is. i hate GM corporate colors too. I dont really care about bolts getting painted or anything i just wanted it done quick and i thought paint it now was better than no paint at all.
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
