HELP!! my car revvs itself
Old Jun 17, 2008 | 05:17 PM
91Camaro_RS's Avatar
ok so i kept having code 32 and i read that most people cleaned the hose that connects to the EGR so i did that and it worked great, drove it to school in the morning and it was fine, but on the way home i noticed that whenever i let off the brakes the car revvs itself once and when i got into my driveway i stopped and let off the brakes and noticed that the volt meter kinda fell back a little so i think there might have been a slight loss of power, but does anyone know why it revvs when i let off the brakes,
EGR valve and Alternator were replaced less than a month ago, so i dont think it could be the alternater.
Old Jun 17, 2008 | 05:54 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: HELP!! my car revvs itself
You may have a vaccum leak since you pulled that tube off. Also check for any other vaccum leaks.
Old Jun 17, 2008 | 06:06 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Ity does sound like a vacuume leak, i dunno may be in your break booster?? just a thought
Old Jun 17, 2008 | 06:19 PM
hmmm the tube i pulled off and cleaned was the one that goes from teh EGR up to the intake, and its not really a tube, dik why i said that but its a metal pipe that has ridges and its kinda gold in color, does that have anything to do with the vacuum?
i just went and checked the hoses that i knew were vacuum hoses and didnt appear that were any cracked or leaking vacumm lines
Old Jun 17, 2008 | 08:50 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
If we say vacuum leak then we are referring to any air leak after the TB. So that tube, gasket, or plastic tube could be the culprit. How was the gasket for the metal tube look?
Old Jun 17, 2008 | 09:39 PM
they looked fine, but looks can be decieving, i think i will try replacing those gaskets and do you think that those four bolts holding on the tube might need to be tightened to a certain torque? maybe i didnt tighten it enough...
Old Jun 17, 2008 | 09:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On a '91 there isn't any vacuum lines to the EGR setup. The ribbed metal tube you cleaned transfers the exhaust gases from the EGR valve to the intake.
However, if this metal tube isn't properly sealed to the EGR and intake then a vacuum leak will occur. Either new gaskets or a thin coat of copper RTV will help in sealing it.
As for the slight rev when letting off the brakes. Usually it is the opposite, when applying the brakes the egnine wil rev ever so slightly. This is from the air (via vacuum) moving from the booster to the intake manifold.
As crazy as it may sound, your car may have been doing this all along. It is just that now you are noticing it.
RBob.
Old Jun 17, 2008 | 10:16 PM
yeah i dont think the ribbed tube got sealed all the way, ill try fixing it tonight and for the brakes i did know that it revs a lil bit for the booster and stuff but the revs it was doing was a lot more than it normally did,
Old Jun 18, 2008 | 12:43 AM
alright i got new gaskets on it made sure it was tight and started it and no revving when i started it which was good and when i pressed on the brake it would only do the normal amount to power the booster, so now i just got to see what it does after driving around town for a bit but i think i got it pretty much taken care of
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
