Spark plug numbers...what side is 1-2-3 n 4-5-6
Old Jun 29, 2008 | 04:08 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
I had to throw out my car manual the other day since i had a leak in the trunk n it got ruined.
I just need to know what side is 1-2-3 n 4-5-6.
I THINK 1-2-3 is on the passenger side n 4-5-6 is on the driver?
2.8 v6
Old Jun 29, 2008 | 04:26 PM
firstfirebird's Avatar
Re: Spark plug numbers...what side is 1-2-3 n 4-5-6
My 3.1 is 1,3,5 on the pass side and 2,4,6 on the driver's side.
If it's your origional engine, it should be a 3.1 in 1990.
Old Jun 29, 2008 | 04:53 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
whichever cylinder head is farther forward on the block than the other is where your #1 cylinder is located
this applies to all engines
aso, if you look on the intake runners the cylinder numbers are cast on them near the valve covers, large raised numbers
Old Jun 29, 2008 | 05:09 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
#1 is front passenger side.
Old Jun 29, 2008 | 05:43 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
wut that be the same for the 2.8??
Old Jun 29, 2008 | 05:45 PM
Should be for our cars. I'm not sure about real early 2.8's.
Either way if you put a 2.8 in yours, yes it's the same. Is your's the origional motor? If so it's a 3.1.
Old Jun 29, 2008 | 05:49 PM
fallenleader's Avatar
Car: 1984 firebird
Engine: 2.8 v6
Axle/Gears: soon: A working car.
In a few days i'll scan my haynes book. It has a drawing of it.
Old Jun 29, 2008 | 05:50 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Nah it's a 2.8 from an 89 RS.
Old Jun 29, 2008 | 07:54 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Same firing order as 3.1s. #1 is the front passenger cly and #2 is the first cyl on the driver side.
Old Jun 29, 2008 | 08:55 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Pictures are easier to understand.
Here ya go.
Old Jul 9, 2008 | 07:26 PM
Car: 1984 firebird
Engine: 2.8 v6
I found my haynes book, Its firebird not camaro. if needed I'll post the info in it. Otherwise i'm outta the topic.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
