2.8l stroker
Old Jul 18, 2008 | 09:30 PM
87camaroryan's Avatar
Car: 87 camaro
Engine: v6 2.8
Transmission: 5 speed
Axle/Gears: ??
2.8l stroker
does any one know where you can buy a turn key 2.8l stroker motor?
Old Jul 19, 2008 | 06:52 AM
UK Speedbird's Avatar
Car: 91 Firebird
Engine: 3.1L 191ci
Re: 2.8l stroker
Not tried these guys 87Camaro but it's a site i found a while ago. Looks like they have what ya want.
Speed.
http://www.engine-parts.com/GMV6/gm28stroker.html
Old Jul 19, 2008 | 08:13 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 2.8l stroker
Yep, GM, the wrecking yard, other people.....
A 3.1 is basically a 2.8L that has been stroked.
The above link makes hype of something that is easily available and easy to find.
Old Jul 19, 2008 | 09:03 AM
Car: 87 camaro
Engine: v6 2.8
Axle/Gears: ??
Re: 2.8l stroker
thank you for the info. that really helps me out. just wondering would it be cheaper and easy to buy one alrdy stroked out or do it your self?
Old Jul 19, 2008 | 01:18 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 2.8l stroker
id say spend your money on what youve got and improving it, stroking to 3.1 wont give much hp for the hassle, unless of course your taking your engine out and stripping it down anyways???? then go get some junkyard parts
Old Jul 19, 2008 | 04:11 PM
Car: 87 camaro
Engine: v6 2.8
Axle/Gears: ??
Re: 2.8l stroker
i have plans on putting a Dynomax Performance catback exhaust, PaceSetter Performance headers, MagnaFlow high flow cat., 2 k&n air filters, Hypertech computer chip, Mallory High Performance Replacement Coils, Mallory Unilite Distributor. is there any other small cheap things i can do to my 2.8l to get the horse power up? or does any one know any parts that are better to use then i put up or that are cheaper and do the same thing? im new with the 2.8l and i dont really know where to go to get the after market parts for it so far this is all from summit racing.
Old Jul 19, 2008 | 05:42 PM
Car: 91 Firebird
Engine: 3.1L 191ci
Re: 2.8l stroker
I see where you are going with the upgrades 87Camaro, all those things you mentioned will give you extra hp but it'll only be very small improvements from what I've herd from the guys on here, which then begs the question is it worth it? I think the only surefire way of getting more hp from the V6 is either to go with a Turbo (think someone does a kit on here?) or drop in a 3.4 from a 4th gen. As far as I know the 2.8, 3.1, and the later 3.4 are all very much the same and will drop into exsiting engine mounts. (correct me if i'm wrong guy's??) The only other thing you could do would be to put a V8 in. As for shops that sell all that stuff, well I live in the UK and as you can imagine we don't have one's that sell any upgrades for the Camaro/Firebird! My Firebird is stock which is just as well seeing how gas is $2.4 a litre over here!!!!!! Anyway, summit is just about the best place for all your speed stuff I get most of my bits from them (spark plugs, filters etc) Sure someone'll shoot me down about that lot but thats what i think anyway
Speed.
Old Jul 20, 2008 | 09:34 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 2.8l stroker
yeah speedbird would be nice if we could just go to the junkyard and pull a 3.4 from a smashed 4th gen eh ? these guys dont know how good theve got it LOL.
Old Jul 20, 2008 | 10:05 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Re: 2.8l stroker
either pull a 3.4, or grab a newer 3.8 from the later camaro's... our 2.8/3.1's are outdated and won't give you the mpg like the newer 3.8's or 3.4's
Old Jul 20, 2008 | 10:48 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: 2.8l stroker
are the 3.8s bolt in or do they take more work than just an engine swap?
Old Jul 20, 2008 | 11:15 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 2.8l stroker
alot more work as the 3.8 is a 90 degree engine and completly different. the 3.4 is the same as the 2.8/3.1 blocks and slots straight in. if you know what your doing the 3.8 is a sweet motor - i had one in my 4th gen maro.
Old Jul 20, 2008 | 12:34 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: 2.8l stroker
If your 2.8 is running fine and you're just looking for more power... put a turbo on it. I have a bolt on turbo kit for sale that I can't use anymore if interested.
Old Jul 21, 2008 | 03:42 PM
Re: 2.8l stroker
hahaha, no thats ok. I was just asking for a friend we were talking about if it was easy to do or not. I'd like to go turbo, but I don't have the money and I'm putting my build together now anyway.
Old Jul 22, 2008 | 03:10 PM
Car: 91 Firebird
Engine: 3.1L 191ci
Re: 2.8l stroker
So true! There was one for sale last month in a Worksop scrap yard but by the time I found out it'd been sent to the smelters!
Just as well mines running like a dream!
Old Jul 22, 2008 | 04:30 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 2.8l stroker
no way ! gutted, i had thought of buying a cheap 4th swapping the blocks and selling it on - shhhh theyd never know !!!! they shouldnt be looking at 4th gens anyways haha
Old Aug 14, 2008 | 09:35 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
Re: 2.8l stroker
how much do ya want for that bolt on kit?
Old Aug 15, 2008 | 11:38 AM
Re: 2.8l stroker
I've been asking $500 or best offer for:
-garrett t3 50 trim turbo
-modified y-pipe with stainless turbo flange
-stainless steel down pipe with adjustable internal wastegate and O2 sensor bung
-used 19# injectors from 86 Trans Am 305tpi
*good for 7 psi
For the "stage 2" kit I've been asking $700 which includes:
-above parts
-modified MAF ecm with custom chip
-24# LT1 injectors
-to4e 60 trim compressor housing (currently installed on turbo)
*good for 8-10 psi (then you need an FMU or V8 MAF because the MAF sensor maxes out)
All you will need are oil lines and intake pipes (intercooler if desired). The 3.1 engine requires custom tuning. Other than that, this is a pretty straight forward bolt-on. I can show you where to get oil lines for cheap.
I also have some stock exhaust manifolds with some pretty new bolts that I've been offering free with the kit, but since the buyer pays all shipping it just adds shipping cost.
A link to a folder with some old pictures that have these parts in them:
https://jshare.johnshopkins.edu/aschlot1/turbo2.8v6
~Aaron
Nervous2
Oct 8, 2015 10:53 PM
bplessy
Sep 30, 2015 12:14 PM
Chevykid810
Sep 28, 2015 12:57 PM
JSDaddy189
Sep 26, 2015 03:50 PM
