Lost Power
Old Jul 31, 2008 | 03:02 PM
elzaco29's Avatar
Lost Power
i own an '88 camaro with a 2.8L. the engine loses a significant amount of power after it has warmed up; if feels as if im dragging a boat behind me. also, every now and then the trans shifts late into second and third gear. other than these things, the car runs like a dream.
is there anything i can do about the first problem or is that just normal for these 2.8L engines?
as for the second part, is it a trans problem or do you suppose the computer chip is malfunctioning?
Thank you to anyone who can help me! ;D
Old Jul 31, 2008 | 05:34 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: Lost Power
I'd say do the basics, check all your vaccum lines, filters, plug gaps, injector cleaner. Normally once there warmed they usually dont perform as well, but if its as significant as you say then just start pokin around. How many miles does it have? As for your tranny I'm not the best source but has it ever had a transmission flush? How does your fluid look? Is it low?
Old Aug 12, 2008 | 09:01 PM
elzaco29's Avatar
Re: Lost Power
sorry for the late response, went camping for a while....
i'll do the best i can for now. not much money to spare right now with tuition and all. you're info will deff help push me in the right direction.
thanks!
Old Aug 14, 2008 | 04:37 PM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: Lost Power
yeah i've sort of noticed that on my 2.8 as well, but the loss of power isn't that significant.
so is this normal? and why?
Old Aug 14, 2008 | 05:20 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Lost Power
The motor goes into closed loop once it warms up. Once it warms up the O2 starts to monitor the air/fuel mix in the exhaust so your injectors aren't dumping fuel into your engine anymore. Mine runs rich so I don't notice much of a difference at all.
Old Aug 14, 2008 | 06:31 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Lost Power
What are your water temps???
Mine use to get real sluggish when it got warm, till I got my temps under control. 185-190 is the best, once ator over 200, things go down hill.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
2QUIK4U
Aug 26, 2015 04:40 PM
sailtexas186548
Aug 24, 2015 10:11 PM
db057
Aug 22, 2015 08:17 PM
