how to check iac ?
Old Aug 17, 2008 | 08:45 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
how to check iac ?
hi, i have hanging revs when lifting off, i believe could be iac but how do i check it? nout in the manuals apart from how to replace ? i took it out and flicked ignition on to see if it moved but it didnt so i have the feeling its bad.........
Old Aug 17, 2008 | 09:57 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: how to check iac ?
I think the reason you didnt get much replies is because..to check it ,you need a scanner that has the IAC testing feature.I bought a noid light to check it, but didnt realize I needed a scanner to use it.My Auto X-ray doesnt have this feature.Only other way is to put a scanner on it and watch the IAC counts.I would try a good one or known good one and see if it changes..
Old Aug 18, 2008 | 12:35 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
ok mate thanks
Old Aug 18, 2008 | 09:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
One thing that you can do is:
Short pins A & B together on the ALDL connector.
Then key-on, engine-off
The IAC will be continuously commanded to close. Usually you can feel the IAC body for it clicking. Not sure on that TB if you can see the IAC pintle. If you can it will fully extend and close off the orifice.
Warning: if you do this with the IAC removed from the TB the pintle will become fully unthreaded from the IAC. And if not retained shoots across the garage and finds the darkest, dusty-est corner to hide in.
To thread the pintle back in, reverse a pair of the IAC connector wires (usually color coded with the same main color and a different stripe color). And repeat the above.
RBob.
Old Aug 18, 2008 | 12:50 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
are they the diagnostic pins that i use to check codes ? my car uses pins 5&6 i can take the top off the TB with the iac still installed to watch it
Old Aug 18, 2008 | 05:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, same pins as used to pull the codes.
RBob.
Old Aug 18, 2008 | 05:06 PM
jstrdn90rs's Avatar
RBob.
Cool never knew that..I did have a pintle come off and it stuck inside the orifice in the TB..that was the only code I have ever had on my car.I removed it and took it back to the auto store cause I didnt like it as the tip screwed on and off and bought a Delco or Dephi brand(been awhile) it didnt screw on or off the shaft.Yeah you can remove the top cover off the TB on the V6 and probably watch it from there.
Old Aug 24, 2008 | 08:37 AM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
My 86 does the same thing. I have disassembled and completely cleaned the IAC motor and pintle assembly, but with no avail... Small vacuum leak somewhere perhaps? One of these days, I'll get around to just changing out the IAC and see what happens...
Old Aug 27, 2009 | 07:47 PM
1970 Buick's Avatar
Car: 1989 GTA
If you can't feel the IAC "clicking", does that mean it is bad?
Old Aug 28, 2009 | 08:58 AM
jstrdn90rs's Avatar
it could ,but also could be.. its not getting a command from the computer.
Old Aug 28, 2009 | 09:51 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
How much of a hang in RPM? Member the stick cars computer chip is programed to hold the rpms a sec or so longer to aid in shifting.
only really know as when guys puts a stick chip in an auto car and then its ubar obvious and makes folks ask.
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
