turbo question
Old Aug 21, 2008 | 06:08 PM
T215D4's Avatar
turbo question
could i run a td05h 14b turbo without needing to upgrade my fuel pump.
Old Aug 22, 2008 | 02:39 PM
xiholdtruex's Avatar
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
Re: turbo question
you can run anyturbo without changing your fuel pump but i would not suggest it.it might lean out inturn not supply enough fuel to your engine which is a bad thing.
Old Aug 22, 2008 | 02:45 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: turbo question
You need to un-do the stock regulator and go adjustable and then maybe.
On the dry nos system holley sells for our car, they use a return line switch that block the fuel, to over ride the regulator to boost fuel.
Old Aug 22, 2008 | 03:36 PM
firstfirebird's Avatar
Re: turbo question
All depends on how much more power you want to add. You will be safe for moderate boost (5-7psi).
The bigger question is, what are you going to do to increase the fuel delivery with the boost? If you are not planning on tuning the ECM, then you need to, at the least, have a rising rate fuel pressure regulator (AKA fuel management unit, as Gumby mentioned) and raise the fuel pressure linear with the boost pressure - making the injectors have a higher flow rating.
Also, it's not a bad idea to get some way of data logging, or even a wide band o2 sensor to monitor the spent gases for oxygen.
Old Aug 22, 2008 | 08:57 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: turbo question
How much psi is the stock pump capable of delivering?
Old Aug 28, 2008 | 02:43 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Re: turbo question
If you have the means, time, and $$$ to run a turbo why would you skimp on a very important part of a turbo system? Replace the pump, it's not that hard.
fasteddi
Sep 2, 2015 10:29 AM
lt1z350
Aug 28, 2015 05:57 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
