Just beacuse it's not running right now...
Doesn't mean it can't look good
I used Mother's clay bar on the entire car, good product...
I my bay didn't have the mock-up engine in there, I'd drive it to some better scenery...
They will meet soon enough....
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Just beacuse it's not running right now...
Car looks like crap :P
JK. I want to see this car up and running.
Transmission: 5-speed/T-5
Running > looking good.
:P
:P TGO Supporter
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
With what little stuff is removed, I can still tell you have more front fenderwell gap then the rear.
Maybe the hairdryer will add enough to level it out
The block is only the block, timing set/cam, and crank. The top end in there for mock up is also ~40lbs lighter than the iron counterparts, not to mention the heavy cast iron manifolds and exhaust is gonzo.
Trust me, there will be plenty of weight added to the front when it's all tied up.
Car: 89 V6 Camaro
Engine: 2.8
Car: 89 V6 Camaro
Engine: 2.8
I didn't realize that you had put all of it back in. Those look like the older pics you posted with the motor mocked up in the car.
Very clean!
That engine looks lovely as well, should go inside the bird nicely.
I've washed my car 3 times the past three weeks... and they're just as dirty as they were the day before I washed them. Why? They're doing construction on my street... messy SOBs! They need to hurry up., damn it!
that engine looks like it wants to run some 93 octane with 2 turbos and an aquamist kit squirting in that ice cold denatured alcohol. Man i bet with proper tuneing you can squeeze 500 RWhp outta that
damn i wish i had the pipeing to put a turbo in my car. I wish someone sold just the pipes i can even weld it all up just need everything to match up so i wont have to build it all myself.
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Looks good. You finally got time to work on your project?
Seeing all this makes me upset that Im not farther than I am
I need to tone down my other "hobbies" and get my car done....so I can come down there and show your car my tail lights
Yeah, I've been lucky lately and had some time the past cple weekends. I might take some time off tomorrow and complete at least one side of the primaries
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
