is this normal? getting pretty hot but not overheating
Old Aug 12, 2008 | 03:21 PM
91Camaro_RS's Avatar
i was drivin to the race track the other day and i was getting on the freeway but i got stuck in some rush hour traffic and i looked at my temp guage and it was at 200 but its been there before so i wasnt to worried. then a few minutes later i looked at it again it was at 220, then a few minutes later(still in stop and go traffic) it hit 240, now i starting to get a little worried so i turned on the heater on full and that lowered the temp a tad. once i got going about 50-60 it started to cool down but never went down past 200.
could these be a stuck thermostat?? or just a bad one
what about the air dam on the bottom of the car mine is curbed pretty bad would a new one help get air to the radiator?
Old Aug 12, 2008 | 04:06 PM
crazyblue92's Avatar
Re: is this normal? getting pretty hot but not overheating
My car does that too it runs nice and cool but if i get into trafic jams it climbs like crazy my lower air dam is curbed reall bad too ive tryed everything but that to keep the temps down it drives me crazy
Old Aug 12, 2008 | 04:18 PM
yeah it drove me nuts to cause i was just about to race so i was racing with it at like 220
Old Aug 12, 2008 | 04:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
All I ve done to mine was the TB coolant bypass, I have a true cold air/ramair
[airs come for directly outside into engine]
And I made my own front replacement for the air dam.
Was all broken to bits from curbs.
Took a piece of aluminum drip edge and stomped it flat, painted it black and screwed it on.
Also the AC rad was removed [ac no wokie]
Long as I am moving it never goes over 180, that is without a fan.
I don't run a fan, its switched and turned off 99.8% of the time.
I only turn the fan on a few tiems a year sitting in a long line at the drive through or at the bank, no problems even in slow traffic.
Though its also a stick, so I don't have the trans pumping heat into the water.
Old Aug 12, 2008 | 08:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not unusual, the stock calibration turns the fan on at 226 F. Unless the A/C is on. Then the fan is on whenever the A/C pressure switch is open (high pressure in A/C system).
Of course if you are using the "cosmetic gage package" for engine temperature, the real engine temperature can be far from that reading.
RBob.
Old Aug 12, 2008 | 09:07 PM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
i had the same problem to! but i came accross this artical from super chevy and never ever had the same problem if you want to know what exacly i did to my 91 RS Camaro just google "Keeping a Third-Gen Camaro Running Cool i hope this helps
Old Aug 12, 2008 | 09:21 PM
id like to see some pics of your set up Gumby
Old Aug 12, 2008 | 09:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Pics of what stuff?
Old Aug 13, 2008 | 01:01 PM
maybe the alum drip edge ??
Old Aug 13, 2008 | 01:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its real cheesy and there is nothing special about it, cept thats it there.
Its somerthing I had laying around that was stiff enough and fit right and unless up close you can't tell. [needed some paint in pics, as it hold up well to curbs.]
You just need that front lip to catch fresh air and feed it up.
I found that out when I tried to make a front spoiler, looked real cool but screwed up the air flow from down there and my temps went up up up and it cam off off off.
Old Aug 13, 2008 | 04:14 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It actually sounds like you have a radiator cooling fan that's inop for some reason. That's why it only happened when you got into stop-and-go traffic. Under cruise conditions, the natural air flow across the radiator forces air through and cools the coolant, but in low speed conditions, the fan is needed for airflow. Warm you car up and see if the fan comes on right around the 230* mark, if it doesn't you will need to check out the power and control circuits for you radiator fan to get it working again.
Old Aug 13, 2008 | 05:14 PM
ok ill try that but how do i heat it up to 230, should i go on the free way and find stop and go traffic then pull over and check, or is there a easier way
Old Aug 13, 2008 | 07:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can just leave it sit and idle in the driveway. Leave the A/C off, otherwise it will turn the fan on.
RBob.
Old Aug 15, 2008 | 03:07 PM
ok ill try that, and i dont have A/C
Old Aug 27, 2008 | 05:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You can find air dams on Ebay for $25-30
http://myworld.ebay.com/ebaymotors/perrypam
Old Aug 29, 2008 | 07:10 PM
yeah ill be getting one of those here soon
Old Aug 29, 2008 | 08:03 PM
bfrd22's Avatar
Car: 1988 Trans Am GTA restoration proje
Engine: 5.7 TPI
Axle/Gears: 3:27
Air Dams are Cheap at your Local dealership too. I was surpised, cheaper than ebay was with shipping. And all new hardward and fastners to boot!
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Strick1
Sep 4, 2015 07:11 AM
