pully set up
pully set up
hey if anyone could help i have an 88 camaro with the 2.8 changed the mortor with a 82 2.8 now when i got the car the mortor was taken apart a little. any how the 82 have drive belts and the car had a serpentine pully setup and i like to use that i have all the pullies and need a pic if any one have one on how it all go's and i am missing the smog pump.do i need this to use the pullie setup?Thank You.
Re: pully set up
Use the pulley's and brackets from your car. There are lots of pics floating around here, but I can dig some up if you can't find it in your search. Look for key words like "smog delete" etc.
Transmission: 5-speed/T-5
Re: pully set up
You willl need to use the newer, serpentine front cover, to match with the reverse rotation water pump, along with the oil pan to match the front cover.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: pully set up
A little off topic here. But which heads are you using? The 82 motor that was installed was likely a carbed motor which had the smaller heads on them. The 88 heads you pulled out would be better heads.
Re: pully set up
Adding to that, the 82 motor also has smaller main journals on the crank
Re: pully set up
so your saying that the oil pan from the 88 block will bolt on to the 82 block?cause man when i first pulled the mortor i'm useing i pulled it outa my 86 firebird that i crashed last winter so i thought it was an 86 2.8 went and changed the oil pump had the hardest time finding the right gasket for the oil pan. we found it under an 82 2.8..
Re: pully set up
'82 to '85 oil pan gaskets are all the same.
The reason you need to change the oil pan, is because the front cover has a different flange where it meets the oil pan.
Re: pully set up
Ohhh OK. thanks for everything it makes me know what i have to do so i'm just gunna leave it with the drive belts for now thanks again on that.but i do need to ask on another on.the is one plug that can't plug in and thats the onethat plugs on top of the Altenator cause it has a 3 wire plug and i am useing an Altentor with the 2 wire plug.can i just get the 2 wire plug and spice it and what wires do i use outta the 3?
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
[Sold] Accel 30# injectors
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
