2.8L Top End Rebuild Pictures
Old Sep 7, 2008 | 11:21 AM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
Here are some pics from my rebuild project:
www.1988firebird.shutterfly.com
Does anyone think rebuilding only the top end will cause problems for the bottom end? Stronger top end + weaker bottom end = problems?
A few problems/questions I've ran into:
1. Stock setup does not have exhaust manifold gaskets. I've researched here and it seems pretty evenly split on adding gaskets. I think I'll just put back on the way it way (no gaskets).
2. Two broken bolts on the exhaust manifold. No wonder I had that annoying popping sound when up-shifting. I always thought it was the deceleration valve.
3. I'll be using the higher performing Viton o-ring for the distributor.
Things replaced:
Distributor-Delphi brand. I believe this is new, not reman. $250.
Injectors-Also Delphi brand. New. $100 each.
All gaskets.
New push rods and rocker arms.
Heads should be back from the machine shop on Tuesday. I'll post more pics then.
Old Sep 7, 2008 | 10:47 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Re: 2.8L Top End Rebuild Pictures
Are you not rebuilding the bottom end? I'm a believer that when you tighten the head gaskets on a high mileage motor you run the risk of blowing the rings. Just my experiences. Your heads look really similar to mine when I did it.
I ran gaskets on mine and then drilled out the heads for 3/8" exhaust studs instead of the puny stock bolts.
Old Sep 7, 2008 | 11:23 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
he some one didn't drain the coolant before pulling the heads.. i can just imagine that engine letting go after u start it back up..
Old Sep 8, 2008 | 12:09 AM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
I think I'll have the lower end rebuilt just to be sure. Shouldn't be a problem with the coolant that way either.
Thanks for the advice.
-artie
Old Sep 8, 2008 | 01:54 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
You'll still need the coolant out of the oil. However, you can get it out of the cylinders by taking the plugs out and turning it over a couple times if you don't mind the mess.
Old Sep 9, 2008 | 01:13 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Looks like the heads are cracked.
Reman long block from Kragen/Autozone: ~$1300
Junk yard, 25k, off a 89 bird: ~$1100
-will have distributor, injectors,...
I don't suppose I can get a new one anywhere...
hectre13
Dec 11, 2023 08:14 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sreZ28
Aug 14, 2015 07:48 PM
gwade12
Aug 8, 2015 08:17 AM
