fan not kicking on with a/c
Old Sep 10, 2008 | 11:09 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I got my a/c working recently, but the electric engine fan doesn't kick on automatically when the a/c is turned on. According to my Helms manual it should run anytime the a/c is on. The fan does come on as normal when the engine gets to about 220* and cools it down to 180*, but I want it to come on with the a/c like it should so that my a/c is colder. According to Helms the ECM has something to do with this, but that is pretty much all it says.
Does anyone know what to check or if there is a switch or sensor that activates the fan with the a/c?
I have already replaced the fan relay, and I don't want to rig any wiring to make it work, I want it to work like it did originally.
Edit: This is 1987 Camaro 2.8 MPFI
Old Sep 10, 2008 | 11:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: fan not kicking on with a/c
There is a pressure switch on the A/C high pressure line. It is on the passenger side, has a connector with two wires. Should be a blue and a black wire.
With the engine running disconnecting the connector from this switch will tell the ECM that it needs to turn on the fan. No need to jumper anything, just disconnect it. The ECM should then turn on the fan via the relay.
Note that since the coolant temperature switch does turn on the fan, the relay is good. The coolant switch activate the relay in the same way the ECM does, by grounding terminal B.
RBob.
Old Sep 17, 2008 | 10:08 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Tried that. No effect. Any other ideas?
Old Sep 17, 2008 | 11:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Odds are the quad driver for the fan relay is bad. IOW, the ECM is bad.
Could also be the wire from the ECM to the fan relay. Pin D2 (DRK GRN/WHT) at ECM. Grounding that pin should turn on the fan relay and activate the fan. With key-on, engine-off.
RBob.
junior419
Apr 7, 2025 11:35 AM
gta892000
Aug 11, 2019 11:16 AM
codeysabatini
Nov 10, 2015 04:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
