Automatic engine-Manual transmission?
Old Sep 15, 2008 | 11:13 AM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
I'm looking at getting a new 2.8L engine. Problem is that the dealer only shows automatic engine available and I have a manual transmission.
Aren't these engines the same? I would just need to replace the flywheel and such to make it work...
Any thoughts?
Thanks,
-Artie
Old Sep 15, 2008 | 11:50 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Automatic engine-Manual transmission?
Automatic Engine? The only thing that can be auto or manual is the choke and the tranny lol. Flexplate of flywheel dictates what the motor will work with. And some other details.
Old Sep 15, 2008 | 12:16 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
should be able to change the flywheel/install new pilot bearing, put in clutch and go.. and of course the nessisary wireing and vaccum stuff
Old Sep 15, 2008 | 04:18 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
attached picture shows a difference in the engine block itself.
1989 "automatic" 2.8l does not have this tapped hole.
1988 "manual" 2.8l does.
I need the "manual" version.
Old Sep 15, 2008 | 04:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the only thing I can think of for the threaded hole would be for vehicles w/clutch fork, the pivot ball would screw into it. I remember reading about it in the gmpp catalog under the 3.4 hi-torque engine.
Old Sep 15, 2008 | 08:04 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
and what do u have that threads in to the tapped holes that the automatic don't have?
the clutch fork on an 89 is attched in side the bellhousing. clutch cylender bolts right up
Old Sep 15, 2008 | 08:41 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
pivot ball
Old Sep 16, 2008 | 09:58 AM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
know any one thats good with a drill and a tap and die set?
Old Sep 27, 2008 | 01:14 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The engines are identical. That hole is unnecessary. The 3.1 in my car was originally set up for a manual, I think, and was put into my 87 which HAD an auto. Neither trans uses that hole. You will need to get the proper flywheel for the 2.8, since most 2.8s were externally balanced. I believe there was a changeover year to internal balance, but I am not sure of the year... Could have been 89, not sure. And don't forget to buy a NEW clutch kit... might as well replace it while everything's apart. That way you have the pilot bearing as well as a new pressure plate and clutch...
Old Sep 29, 2008 | 06:46 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
thanks
Old Sep 30, 2008 | 02:27 PM
jaseman2134's Avatar
Car: 1987 camaro
Engine: 3.1
yea, no problem swappin them in. i just finished doing that myself.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
aharvel50
Sep 21, 2015 07:31 PM
ynk1121
Sep 12, 2015 12:27 AM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
