I want MORE POWER!!!!
Old Sep 25, 2008 | 02:16 PM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
I've got a stock v6 3.1 and already have a good flowing exhaust but need to know some mods i can do for cheap but without sacrificing a ton of money or if possible without hurting my gas milage. ANY HINTS???
Old Sep 25, 2008 | 02:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: I want MORE POWER!!!!
Mostly any mod will cost you a chunk of change.
I would have the y-pipe rebuilt to more of a true Y then a T.
Also change the air intake.
Old Sep 25, 2008 | 02:51 PM
startercar's Avatar
I'll hopefully soon have a 91 Bird with the same motor, so I'll be listening in to this thread
Old Sep 25, 2008 | 03:30 PM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
If my dad would of let me i would of got one with a 305 or 350
Old Sep 25, 2008 | 07:48 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
You want more power? This question gets asked a lot. I would read the stickies and do a little searching.
How much HP are you looking to get?
As suggested, I would look into the exhaust and intake. If you don't have to worry about emissions I would get a set of Pacesetter headers.
Old Sep 26, 2008 | 09:21 AM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
It sound like to me you want nitrous cheap power = nitrous get a sniper wet kit the one made for 4 cyl cars it has a 35,50 and 75 shot and its only like 300 bucks on ebay. It will take you like an hour or 2 to install if you follow instructions. Start with the 35 and work your way up.
Old Sep 26, 2008 | 01:29 PM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
no not nitrous per my dad and like i said i've already got a great exhaust on are there any superchrgrs on anything bolt on that would work nicely like from a junk jard?
Old Sep 26, 2008 | 03:01 PM
Dale's Avatar
Engine: 350 S-TPI
What do you consider "good exhaust". If your talking just a muffler or catback.... that is not the choke on these cars. Its the "y"-pipe that is more of a T.
There are no direct turbo or SC kits for these cars. Turbo seems to be the fav and many are in the process and talks right now. Do a search and you will see a decent list of cars you can jack parts from and make your own kit.
Old Sep 27, 2008 | 05:02 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I was planning on putting a M90 in my bird but it has a 3.4 and I ported the top end and opened up the exhaust and im happy with how it runs now. I am saving the M90 for a 3.4 hybrid that would go in my vega that is built for autoX.
Old Sep 28, 2008 | 12:04 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Put some 3.73's in it. Won't be making any more power, but it sure will feel like it.
Old Oct 5, 2008 | 08:36 PM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
if i did the 3.73's do i swap out the stuff that lets me see the correct speed im going idk is there a speed cable or what?
Old Oct 6, 2008 | 07:34 AM
grimmcs's Avatar
Car: 91 Camaro
I believe there is a little gear in the tranny that you have to swap. I looked into that before...but havent made it that far.
Old Oct 8, 2008 | 11:55 PM
tank12983's Avatar
Car: bandit II Firebird
Engine: 3.1
Transmission: auto
this question does get asked often and often its gets answered with "use the search" but the search is in dire need of a tune up so here's my . first thing home made CAI costs like $60 and you do feel it. after that exhaust, pace setter headers. now they are not cheap but you can really feel and hear that. but thats only if your not worried about emissions. and from there it gets kinda complicated with custom turbo setups and 3400 hybirds and nitrous.
i saw a really great little saying on here once but i don;t know who said it but it goes a little some thing like this
cheap+easy=not pretty
pretty+cheap=not easy
pretty+easy=not cheap
Old Oct 9, 2008 | 09:11 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
V6 + want power + don't want to spend money + no nos
= idiot.
Just drive that hunk of junk!
Old Oct 10, 2008 | 12:20 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
Have you thought about a hypertech thermo master chip? I don't know if I got any more power, but it solved my running hot problem and I def. got a little more mileage from the plus gas I use.
Old Oct 10, 2008 | 07:44 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
When you find this unicorn, you be sure to let us know.
Old Oct 11, 2008 | 08:58 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
lol, magical.
you could cut off some or all the bottom air boxes, like mine. I don't know if it made any more power because I did this before the car ran, but I did it to my friend's and he said it was a definite difference.
Old Oct 11, 2008 | 03:56 PM
grimmcs's Avatar
Car: 91 Camaro
Wont work for him... he has a Firebird.
There are a bunch of things that you could upgrade that would make the car run smoother and have a better ride...but if you want more HP a couple hundred bucks...at least.
You have a "free flowing" exhaust? Aftermarket? Cat-back? High-flow cat? Headers?
Unfortunately if you want the SC/turbo route it has to be custom. It can be done semi-cheaply....but you get what you pay for.
I would say the easiest way to get a few extra HP is to upgrade the intake and exhaust.
Old Oct 12, 2008 | 12:03 AM
bl85c's Avatar
Car: '85 maro
Agreed, make it suck and blow.
Old Oct 12, 2008 | 07:31 AM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
Modify the 'Y' pipe or get a bigger diameter one 9as i did) with headers its a welcome change and sure sounds lovely at idle.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
