Quandry.....degreeing of crank and/or cam
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
I'm in a bit of a quandry as I start putting my engine together. It's a 2.8 stroker (so 3.1 pistons and crank). I'm putting in a CompCam 260 grind cam, 1.52 roller tip rockers and a Cloyes double roller timing chain.
So, according to the instructions for the timing set and the cam, I have the option of degreeing the crank and cam or neither. If I advance the crank, I supposedly get more high end hp, if I retard, more low end torque. I know I'll have to check block clearances, etc. Degreeing the cam makes sense to check for and correct any irregularies.
My question is, is it worth it or should I just go with the stock settings - keeping in mind that this is my daily driver and I don't want to hurt the mileage too much.
Gary.
Gary.
Re: Quandry.....degreeing of crank and/or cam
just install it stright up. no sence in going to hi rpm power cause well the intake is a long runner.small plenum design and just isnt well suited to high rpms.
and to gho the other way with it would work but for more low end power u should have went with the 252 cam which is more of an rv/towing cam
Transmission: 5-speed/T-5
The 260 cam will work fine, it's what I used in my hybrid a few years ago and was happy with it.
If you're not into trying it all 3 ways, I would just install it straight up, this will work well.
FYI, you don't "degree a crank", you "degree a cam". The cam timing and more specifically valve timing events in relation to piston travel is what is being measured when degreeing a cam.
Thanks for the input and the correction. When I installed the timing set, the instructions talked about degreeing the crank as it had three postions on the crank sprocket.
I did in fact install it straight up as I gather the 260 cam already is advanced 4 degrees.
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
