"Back to the Future" boost at 3000rpms
Old Oct 3, 2008 | 01:42 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
My car has no power under 3000rpms. When I finally hit 3000rpms, something happens and the car gets a HUGE boost (kind of like Marty McFly in Back to the Future, when the DeLorean hit 88mph).
Car ran just fine before my reman engine was put in. Here's what's new:
Engine
Injectors
Distributor
Cap
Wires
Rotor
Plugs
Coil
IAC Valve
Clutch
Timing is good.
Runs smooth throughout range and idles smooth.
Vacuum lines are good.
Does the boost at 3000rpms give anyone a clue to as what is happening? By the way, I was not transported through time either.
Thanks in advance.
Old Oct 3, 2008 | 08:29 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: "Back to the Future" boost at 3000rpms
maybe the tranny kicks down????? ZR1 servo in the tranny???
Old Oct 3, 2008 | 08:58 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
It's a 5speed manual.
Old Oct 4, 2008 | 11:10 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
have you tried reving it in neutral to see if its the engine or drivetrain?
Old Oct 4, 2008 | 11:24 AM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
it's fine in neutral.
Old Oct 4, 2008 | 12:15 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Check the flux capacitor
sorry had to do it
Old Oct 4, 2008 | 10:43 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
That's where the torq curve picks up. It's pretty lazy up to about 2k then it wakes up and really comes in at 3k rpm. Is it weaker below 3k than it was before the rebuild or was it so weak before that you're only noticing the pickup now?
Old Oct 4, 2008 | 11:23 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
I'll tell you that my old engine with 315k miles had a lot more power at all ranges. There's got to be something wrong.
Old Oct 5, 2008 | 05:03 PM
if its fine in nuetral maybe the drivetrain was put back on incorrectly or something. does the new engine sound healthier than the old one?
Old Oct 6, 2008 | 11:42 AM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
new engine sounds good. Fuel pressure checks out good. We're going to have a dyno test done today.
Old Oct 6, 2008 | 04:56 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Put in a new distributor and it seems fine.
Old Oct 6, 2008 | 07:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
sounds valid, over 3k it wasn't abel to wobble around in worn out shaft bushing.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
