Not taking any chances
Old Oct 5, 2008 | 01:23 AM
project89's Avatar
got a set of these on the way for when the new turbo goes on
paying 55 bucks each bushed for the smaller pins on the v6 pistons
gota love it when ur old sponsors come back threw for pet projects
manley was a sponsor of our old tad dragster and now that we dont have it anymore they come threw for us now and then with stuff like this
now only if i could get one of our old contacts over at je to get me a set of pistons out the door this cheap
Old Oct 5, 2008 | 03:24 AM
nope's Avatar
Re: Not taking any chances
wow! that looks awesome! how do they weight in compared with stock rods?
Old Oct 5, 2008 | 11:34 AM
project89's Avatar
these weiigh aprox 630 grams but machining them down to fit the v6 crank widdth will make them a lil lighter so prolly 600 grams
i dont recall the wieght of a factory rod but i think its in the mid 500's
manley rates these things to 8,700 rpm and 800 hp depending on stroke and piston wieght so should never have to worry about putting a rod out the side of the block with these.
i was starting to get a lil concerned when i relized just how much power im making at the crank and how high im actually turning this motor.so for the price im getting i couldnt say no, im getting these at less cost then it would to buy and modify a set of 327 small journal stock rods
Old Oct 5, 2008 | 07:45 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
so what times did you run on the 24th?
Old Oct 5, 2008 | 07:48 PM
project89's Avatar
we havent run since the 13.008
im out of injector and just about out of turbo
making around 380 crank hp and the turbo is only good for about 425 crank
i have some methanol injection stuff comming in along with a bigger turbo and injectors
ive parked the car for now no sence in trying to run any faster when my injectors already went 110% on me last time out
the afr's actually went as high as 15.5-1 in the last 400 ft of the track on me on that 13.008 run
i could run faster if i backed off a few psi of boost and didnt go lean but its like why risk it when i know my fuel system is already strianed
Old Oct 10, 2008 | 07:51 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Originally Posted by project89
Sure does look "Manley"
Old Oct 10, 2008 | 07:59 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Old Oct 11, 2008 | 09:02 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
you had to say that about a rod. of course its manley. lmao
Old Oct 13, 2008 | 12:24 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
It's 'through', not threw!
Hotrodboba400
Dec 10, 2019 07:07 PM
Johnoooooo
Sep 22, 2015 08:55 AM
buckshot63
Sep 10, 2015 09:15 AM
89 formula TPI
Sep 8, 2015 08:00 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
