MY Coolant Keeps Turning Brown...
Old Oct 21, 2008 | 06:04 PM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
I've changed my coolant 5 times in the last year. After about three days driving, it always turns a rusty color. What's happening? Is there an additive that would help with this? I only use 50/50 glycol water premix.
I'm hoping this is just a rusty radiator, but fear it's a sign of a larger problem... maybe rust in the engine?
Old Oct 22, 2008 | 01:26 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: MY Coolant Keeps Turning Brown...
freeze plugs is all i gotta say. flush after new plugs rust should not come back.
Old Oct 22, 2008 | 11:00 AM
Engine: 3.1 V6 MFI
Is that expensive to fix? Can I do it myself? Where are they?
Old Oct 22, 2008 | 05:57 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
back of the engine have to pull the tranny /flexplate to see them... plugs are cheap. labor is not.
Old Oct 22, 2008 | 06:22 PM
Z28baynard's Avatar
Car: 1987 camaro z28
Axle/Gears: ??
this is that your rad. is full of rust. you can do a couple of things.: buy a new radiator or have it flushed. personally i wold just buy a new one, cause its not that much and you can upgarde it so it helps the car preform better.
Old Oct 22, 2008 | 08:41 PM
Engine: 3.1 V6 MFI
Thanks z28. If you had to buy a radiator tomorrow, which brand would you get and where would you get it from?
Old Oct 22, 2008 | 08:44 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
i hope u figure it out. id still take the trans cover off and look with a flashlight if possible to see any rust on the freeze plugs. or coolant leakage. they tend to leak when rusting.
Old Oct 22, 2008 | 08:51 PM
Engine: 3.1 V6 MFI
I was planning on calling the local tranny place tomorrow. I need them to do a couple of other things for me, like put on my new poly t mount. So I was taking it in soon anyhoo. I'll get a quote and then decide if I'm going to have it done.
I've always wanted to upgrade the radiator but wasn't sure where to start. The only ones I've seen have been like 500 bucks. That's why I wanted the recommendation on that. Who knows, it might fix it. If not oh well. I never drive the thing. I'm a Ford man myself. The Maro is just something to work on.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
