Alternator set up
Old Oct 28, 2008 | 01:06 AM
joejoedawidth's Avatar
Car: 86 Firebird
Engine: 2.8L of fun
Alternator set up
Hey guys I just picked up at 86 Firebird to be a project car and a DD, i got tired of the comfortable settings of an 02 Buick Century, any way fast foward to this week my alternator is dead, before I install the new one when it gets in the set up to the battery from the girl i got the car from was a wire stright from the alternator to the positive battery ternminal, how can i hook this up right.
thats the set up on the car now, worked fine for a week or two but im afraid that that wire is what cause the alternator to crap out, i just want to make sure it would be ok to run it with out any regulation on the line
Old Oct 28, 2008 | 01:09 AM
project89's Avatar
Re: Alternator set up
the regulator is built into the alt, it only has the wire form the post on the back to the battery terminal
Old Oct 28, 2008 | 02:10 AM
Car: 86 Firebird
Engine: 2.8L of fun
alright thanks, and is it normal before an alternator goes, that the regulator might go? the day before it completley went the voltmeter was showing 19-20 reading and if it hit 20 the CEL came on then went off, i resovled that issue by running with the lights on with high beams on and heater on, Rear defroster
Old Oct 28, 2008 | 11:11 AM
project89's Avatar
yeah if the regulator blows out the alt will just put out as much voltage as it can.
Old Oct 28, 2008 | 11:48 AM
Car: 86 Firebird
Engine: 2.8L of fun
so would it be a safe theory that if the regulator went it would cause the alternator to put out as much juice as posible causing it to burn out?
Old Oct 28, 2008 | 01:57 PM
project89's Avatar
yes
Old Oct 30, 2008 | 03:04 AM
Car: 86 Firebird
Engine: 2.8L of fun
I ordered a new Alternator untill it gets here i will be making daly stops at Autozone so they charge my battery, the second part of this car thats bothering me is my temp guage always low, the highest i saw it was around 190 and that was once, its always ready like 120-150, i have a new thermostat sitting in the car but my main consern is that its the waterpump, is there a quick way to test the water pump?
Old Nov 19, 2008 | 08:58 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
If it leaks then its bad. Does the motor heat up, do you have good heat? the gauge might just be wrong...
Old Nov 19, 2008 | 09:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
2 things here.
1. Keep this in mind in terms of batteries and alternators: bad alternators kill batteries (and in our cases, ECMs and other things if the regulator craps out, hence the high system voltage code), and bad batteries kill alternators.
2. Our 17+ year old gauges and sending units weren't all that accurate from the factory. Chances are that your gauge is off. If you're not losing coolant or boiling over all the time, don't worry about it.
Cornholio7979
Sep 20, 2018 02:31 AM
Cleotiz
Aug 23, 2015 12:07 PM
Navy8125
Aug 22, 2015 07:13 PM
Dialed_In
Aug 20, 2015 01:45 PM
