You know you can convert the Gen1 block to a roller
Subscribe
Nov 13, 2008 | 04:58 PM
Hi I searched but found little info on this. Will this work on a 2.8?
Reply 0
Nov 13, 2008 | 06:19 PM
Re: You know you can convert the Gen1 block to a roller
short answer no
its starves the crank and rods of oil
Reply 0
Nov 13, 2008 | 09:15 PM
What he said. You can but it isn't goof for the rest of the motor.
Reply 0
Nov 13, 2008 | 09:20 PM
u can do a solid roller conversion though, i belive crower sells a kit to do this,
imho its not worth it for a street car,sinc eu will have to pull the valve covers every x amount of miles to adjust the valves
Reply 0
Nov 13, 2008 | 10:27 PM
Check out Schneider cam products as well.
Reply 0
Nov 18, 2008 | 12:17 PM
Well you can convert it to a hyd. roller, I'm still not entirely convinced one way or the other that the bottom end will be starved. If you dissect a fwd lifter there's no oil hole underneath the roller like so many seem to think. So it's not going to puke oil on the cam which leaves the rockers as the only other 'puking point'. I can't say that I know there's a difference between the roller & flat tappet valving, but me thinks the rollers would actually be a bit more restricted being that the rockers are roller fulcrum as well. One way or another I'm going to find out once I get my motor finished (someday). All you need to do is clearance fwd antirotation bars and mount a couple studs on the block to hold things down.
Reply 0
Subscribe
