slugish take off
Old Nov 18, 2008 | 12:50 PM
dunnellon86's Avatar
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
slugish take off
well this has been a problem fopr a while and it never relly botherd me till now what its diong is when stoped the car will sometimes just stall and if at a light and i try to just slowley come out of the stop it will act slugish if i floor it she goes and tester day with the car running i poped the hood and moved the thrittle by hand and after 1/4 inch or so she droped in rpms and after 5 or 6 sec she sputterd and backfired and as soon as i let the throttle go back to idle thr ran fine eny ideas would be awsome thanks
Old Nov 18, 2008 | 03:02 PM
BthomasM's Avatar
Car: 1990 Firebird / 1999 Eclipse
Engine: 3.1 v6 / DOHC 2.0
Transmission: Automatic / 5 Speed Manual
Re: slugish take off
The first thing that I would try is to clean your throttle body. It usually causes it to idle rough when it's dirty. Just go to the auto parts store and pick up a can of throttle body cleaner for fuel injected throttle bodies.
I see you live in dunnellon and that you're a student... do you go to CFCC, if so I think you were in my english class last year. I know he had a red 2.8 firebird that looks just like the on in your picture.
Old Nov 18, 2008 | 04:23 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
yep good idea to clean out the throttle body and iac passage while cleaning.. check the tb gasket. a leak there can cause rough idle/ hesistation also
Old Nov 19, 2008 | 01:04 PM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
yep thays me going to cfcc il try to clean the throttle boddy out a bit and see that hapens thanks
amshnock
Jul 13, 2014 09:39 AM
TipTricky
Jul 2, 2014 10:02 PM
jjjosh
Dec 31, 2012 01:47 PM
Blue1990camaro
Jul 21, 2012 01:53 PM
godreject
May 25, 2009 12:02 AM
