idle surging
Old Feb 27, 2009 | 07:47 PM
T215D4's Avatar
idle surging
hi i just replaced my valve cover gaskets and now when it idles it will jump to 2,000 rpms once in awhile and then go back down, also when im driving it and let off the gas i can see the rpms jump.
Old Feb 28, 2009 | 12:52 PM
nd4spd42085's Avatar
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
Re: idle surging
look for leaks in the valve cover gaskets, or more importantly check the vacuum lines running over them.....
what year/size engine?
Old Feb 28, 2009 | 02:56 PM
T215D4's Avatar
Re: idle surging
its an 88 firebird with a 2.8. i already checked the valve covers and the vacuum lines are good.
Old Feb 28, 2009 | 03:37 PM
Car: Formula/RS
Re: idle surging
did you replace the intake plenum gaskets when you replaced the valve cover gaskets?
Old Feb 28, 2009 | 04:21 PM
T215D4's Avatar
Re: idle surging
yeah all the gaskets were changed. i just rechecked all the vacuum lines and the one at the far back that connects to the lower intake has a very weak-soft feeling hose that the engine sucs shut and if i puch down on it i can her the idle go back down to normal.
Old Feb 28, 2009 | 04:25 PM
Car: Formula/RS
Re: idle surging
there ya go...
a simple hose and your back on your way
Old Feb 28, 2009 | 04:41 PM
T215D4's Avatar
Re: idle surging
when the motors running it feels like the vacuum is sucking the hose shut.
Old Feb 28, 2009 | 04:46 PM
Car: Formula/RS
Re: idle surging
replace the hose with a stronger rubber hose or a plastic vacuum hose...
Old Feb 28, 2009 | 06:33 PM
T215D4's Avatar
Re: idle surging
replaced the hose now idles at 2000 and climbs.
Old Feb 28, 2009 | 07:40 PM
T215D4's Avatar
Re: idle surging
now im getting a code 21 and 22
Old Mar 1, 2009 | 09:37 AM
Car: Formula/RS
Re: idle surging
code 21 and 22 are for the throttle position sensor...
you could try swapping that out with a junk yard one to see if that's the problem
Old Mar 4, 2009 | 10:52 AM
T215D4's Avatar
Re: idle surging
checked my tps the voltage was fine so i unplugged the battery and it hasn't come back. today i will change the pcv and replace the vacuum lines and see how it goes.
Old Mar 4, 2009 | 11:22 AM
Car: Formula/RS
Re: idle surging
good luck... I hope that solves it for you...
junior419
Apr 7, 2025 11:35 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
