Tightening valve cover bolts.
Old Mar 3, 2009 | 02:44 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Can you easily get to all the bolts to get them tight them without taking anything else off? I'd hate to take one thing off just to tighten the valve covers down.
Ken
Old Mar 3, 2009 | 06:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Tightening valve cover bolts.
If they're leaking, you're probably going to have to pull the intake to replace the gaskets. Otherwise, you might be able to get to the nuts with a minimum of a 10mm deep socket, a u-joint to match, and some patience.
Old Mar 3, 2009 | 06:47 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
They are fairly easy to replace. I had to remove my carb and that was it. I had the gaskets changed in about 2hrs. Its not bad it just takes a while.
Old Mar 3, 2009 | 10:21 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
i tried it, it's unbelievable, but you'll be better off replacing the gaskets and removing everything in the process to make it easier.
Old Mar 4, 2009 | 07:34 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Carb and fuel injection are two completely different setups. and like everyone else said, if youre leaking, tightening the nuts wont help you for long, youre better off replacing them. its not as bad as you think. just get a haynes manual if you dont already have one and follow it step by step. just make sure you get your vacuum lines on and off carefully, theyre probably brittle.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
