oil pressure, is this normal???
Old Mar 6, 2009 | 12:38 PM
Snikker's Avatar
Car: 1998 Pontiac Firebird Trans-Am
Engine: Ls1 Modified intake magnaflow duals
Transmission: 6spd Manual
Axle/Gears: Stock
Today on my commute in to school i noticed while sitting on the exit ramp that my oil pressure needle was bouncing anywhere from 25 to 65 psi,
of course this is a little odd, my engine light came on shortly thereafter. being that everything was running okay i wasn't too alarmed, but this is the second time this has happened to my little 94 3.4 v6. So I would kind of like to find the problem, the first time an oil change did it, but that was too recent for the oil to already have become useless ( last month about Feb 4-5) it does now this is if im recalling correctly have 5w 30 in it, it warmed up outside today(above 40* which for several months has been the high) which may be causing the oil to thin out more than usual. also would overheating (not really "over" heating just running abnormally warm ie: 200-210 range) under this condition indicate anthing that ummmmm....................lets just say might be "expensive"??????????
Old Mar 6, 2009 | 02:06 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: oil pressure, is this normal???
5-30 is ricers oil, the tolerences in our engines are not that tight.
To thin.
Probably the oil PSI sending unit, they go out n act funny.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
